Totally bounded product
In summary: Xq+1).B(x, 1/2) = B1 x B2 x ... x Bn x Xn+1 x ... Summary:The speaker has a problem with a product because it's difficult to understand. If X is metrizable with dn, and if D(x, y) = suo{di(xi, yi)/i} is the metric which induces the product topology on X = ∏ Xn, then X is totally bounded under D.
radou
3,149
I really got a problem with these products.
If Xn is metrizable with dn, and if D(x, y) = suo{di(xi, yi)/i} is the metric which induces the product topology on X = ∏ Xn, show that if Xn is totally bounded for every n (under dn), then X is totally bounded under D. Conclude without using the Tychonoff theorem that a countable product of compact metrizable spaces is compact.
Since Xn is totally bounded for every n, this means that for any n and any ε > 0 there exists a finite covering of Xn by ε-balls. Somehow, I must find a finite collection of ε balls (if ε is given) in X which covers X. Any discrete hint is welcome... I had a few ideas, but they don't work.
Of course, proving the other statement is easy.
If Xi is compact for every i, then it is totally bounded, too. By the previous (yet unproved) result, a countable product X of totally bounded spaces is totally bounded in the metric D. Since X is complete under D (Theorem 43.4.), we conclude (by Theorem 45.1.) that X is compact.
OK, I think I've got an idea. I'll try not to give away to much.
As a first hint: can you describe me the ball B((xn)n,1/3) in the producttopology?
In general, can you describe B((xn)n,r)?
Hm, OK.
If x = (xi) is in (X, D), we have B(x, r) = {y in X : D(x, y) = sup{di(xi, yi)/i} < r}. Here it may be important that if r > 1, B(x, r) = X (because di is the bounded metric on Xi). So cleary, for any ε > 1, the open ball B(x, ε) is a finite open cover for X. It follows that we may assume ε <= 1, right?
Hmm, what you said is certainly correct, but it's not really what we're looking for...
What I want is the following: I want to express B((x_n),1/3) in the form
[tex]B((x_n)_n,1/3)=\prod_{n\in \mathbb{N}}{U_n}[/tex]
where the Un are all open sets in Xn. Furthermore, the most important part is that Un=Xn for all (but finitely many) n.
Try to work out what the Un are in this case.
Hmm, OK...I know this has got something to do with the definition of D, i.e. with the fact that we divide di with i... I'll think about it.
OK, let x be in X.
B(x, 1/3) = {y in X : sup{di(xi, yi)} < 1/3}.
Now, if y = (yn), I conclude the following:
The values di(xi, yi) for i > 3 really don't matter, since their maximal value is 1/i, which is in this case clearly less than 1/3. Now, let's look at the first three components of y.
d1(x1, y1) should definitely be less than 1/3. d2(x2, y2) should definitely be less than 2/3. d3(x3, y3) should definitely be less than 1.
So, if y lies in B(x, 1/3), the first component should lie in the open ball in X1 given with B1(x1, 1/3), the second (in X2, and the same for X3 later on, of course) in B2(x2, 2/3), and the third in B3(x3, 1).
Hence, unless I'm mistaken, we have B(x, 1/3) = B1 x B2 x B3 x X4 x X5 X ...
This is easy generalized, i.e. for any n, B(x, 1/n) = B1 x B2 x ... x Bn x Xn+1 x ... , where for any i = 1, ..., n, Bi is an open ball in Xi of radius i/n.
If this is correct, just confirm please, without further hints, and I'll proceed. :biggrin:
Yes, this is correct!
Hm, now clearly, if ε is of the form 1/n, where n is a positive integer, I can always find a finite open cover for X with ε-balls... For example, if ε = 1/2, we have B(x, 1/2) = B1 x B2 x X3 x X4 x X5 X ... where B1 is of radius 1/2 and B2 of radius 1. Now, since Bi is totally bounded, for i = 1, 2, for B1 take a finite cover for X1 by open balls of radius 1/2, and for B2 take a finite cover for X2 by open balls of radius 1.. The number of combinations of these elements is finite, and any such open ball in X remains an 1/2-ball. So, instead of B1 and B2 we may have Bi x Bj x ... x Bn x Xn+1 x ..., where i = 1, ... p and j = 1, ... q, and this is a finite collection of 1/2-balls which covers X (p and q are of course the numbers of elements of our finite covering collections for X1 and X2, respectively).
This is basically an unimportant observation. I'm still chasing the idea on how to do this or something similar for any ε > 0. Again, I'll point out that the cases for which ε > 1 are uninteresting, right?
Yes, the case where [tex]\epsilon>1[/tex] is not interesting, in fact, only the small [tex]\epsilon[/tex] is interesting.
So you've proven the case where [tex]\epsilon=1/n[/tex]. I claim that this already proves the general case: if you have [tex]epsilon>0[/tex], you can choose [tex]1/n<\epsilon[/tex]. A finite open cover of balls of radius 1/n, will induce a finite open cover of balls of radius [tex]\epsilon[/tex]...
Alternatively, you can also prove a formula for [tex]B((x_n)_n,\epsilon)[/tex] in general. This will be very similar to a formula for [tex]B((x_n)_n,1/n)[/tex]...
OK, this may seem as a stupid question, but how can such a finite open cover by balls of radius 1/N < ε induce a finite open cover by balls of radius ε? I don't see this immediately... If it's trivial, please let me know, so I'll think about it a bit more!
Yes, that occurred to me...A formula inspired by a sequence which converges to ε? :biggrin:
Well, if you have an open cover by balls of radius 1/N, then you just enlarge the balls so that they have radius [tex]\epsilon[/tex]. This will still be a cover of X...
Hmm, I was thinking of the formula
[tex]B((x_n)_n,\epsilon)=B(x_1,\epsilon)\times B(x_2,2\epsilon)\times B(x_3,3\epsilon)\times...[/tex]
Yes, I understand the concept, but I need to find out how..
OK, I'll think about this a bit more and post later/tomorrow. Actually, a few hours ago, I hated this problem, and now I like it! :smile:
It's not that hard: if [tex]\{B(x,1/n)~\vert~x\in E\}[/tex] is a finite cover of balls of radius 1/N, then [tex]\{B(x,\epsilon)~\vert~x\in E\}[/tex] is a finite cover of balls of radius epsilon... You just replace every ball in the first collection by a larger ball...
Aha, somebody's beginning to like infinite products? :biggrin:
YOu won't believe me right now, but it just occurred to me a few seconds ago! It's utterly trivial! :biggrin: I was thinking too hard, I guess...
Haha, I believe you :tongue2:
That's another question solved I guess...
Yes, thanks a lot!
Btw, another simple intermediate result:
For any rational number r, we can find a finite cover for X by open balls of radius r.
This basically follows from the proved case for radiuses of type 1/n.
If r = m / n, one easily concludes that the first ball in the product has a radius less than m / n, the second less than 2m / n, etc... Of course, until for some i, 2i < n is less than 1, the other cases are always trivially true. And this happens a finite number of times.
Edit: of course, we're talking about rational numbers of type r > 0.
Yes, but doesn't that proof generalize to arbitrary real numbers?
Well, that's where my lack of precise knowledge in analysis lacks a little.. :biggrin:
Well, any real number can be approximated with rational numbers, right? i.e. with sequences of rational numbers, more precisely...Perhaps I'm overcomplicating again, but I'd like to see a rigorous proof...
If we construct such a sequence which converges to some real number, then the corresponding "sequence of open covers" (if such term makes sense at all, but actually its important than an open cover in this situation if fully represented with our rational number, or not? is it unique?) "converges" to our open cover with balls of radius ε... Something like that?
Of course, ε is real, so it is in the closure of the rationals, and there exists a sequence of rationals converging to ε.
Edit: so, basically, that's it, I guess.
Edit 2: when I think better, the "uniqueness" I mentioned somewhere in the upper post isn't really important, ignore it.
Yes, all of this should be correct. However, can't it be done much easier.
Take [tex](y_n)_n[/tex] in [tex]B((x_n)_n,r)[/tex]. Then certainly [tex]d_n(x_n,y_n)/n\leq r[/tex]. Thus [tex]d_n(x_n,y_n)\leq rn[/tex]. This shows that
[tex]B((x_n)_n,r)=\prod_{n\in \mathbb{N}}{B(x_n,nr)}[/tex]
Ah, yes, of course!
This holds for any n until rn < 1, then we set the other "factors of the product" to equal Xi.
Well, this is obviously the easiest way to prove it, right?
Yes, I think this is the easiest proof of this. Although I think your method could work to...
OK. Thanks for the n-th time, as n --> ∞! :tongue2:
What is a totally bounded product?
A totally bounded product is a mathematical concept that refers to a set of elements that are completely contained within a finite region. In other words, it is a set that can be covered by a finite number of smaller sets.
How is a totally bounded product different from a bounded product?
A bounded product refers to a set of elements that are all within a certain distance or range from each other. A totally bounded product, on the other hand, refers to a set that can be covered by a finite number of bounded products. In other words, a totally bounded product is a more specific and stricter condition than a bounded product.
Can a totally bounded product be uncountable?
Yes, a totally bounded product can be uncountable. The term "bounded" does not necessarily refer to the number of elements in a set, but rather to their distance or range from each other. Therefore, a totally bounded product can be uncountable as long as it can be covered by a finite number of bounded products.
What are some applications of totally bounded products?
Totally bounded products have many applications in mathematics, particularly in analysis and topology. They are also used in the study of metric spaces, particularly in the proof of the Banach-Tarski paradox. In addition, totally bounded products have applications in computer science, specifically in the design and analysis of algorithms for optimization and approximation problems.
How is a totally bounded product related to compactness?
A totally bounded product is a special case of a compact set. A set is considered compact if it is both closed and bounded. A totally bounded product is bounded, but not necessarily closed, as it may contain limit points. Therefore, a totally bounded product is a weaker condition than compactness, but it is still a useful property in many mathematical and scientific contexts.
