Car Speed When Passing Train: 49 m/s
In summary, at t = 0, the train is 49m behind the car and traveling at 43 m/s while the car is traveling at a speed of 49 m/s. The car passes the train at t = 1 with a speed of 61 m/s.
swimstar
A train is moving parallel and adjacent to a highway with a constant speed of 31 m/s. Initially a car is 49m behind the train, traveling in the same direction as the train at 43 m/s and accelerating at 3 m/s/s.
What is the speed of the car just as it passes the train?
Answer in units of m/s.
Any help would be much appreciated. I have no idea where to start this so if you could lead me in the right direction with equations that would be great.
Can you write some kinematic equations that describe the position of each object along a straight line in relation (as a function of) to time?
It can be assumed that when we first look at these two objects moving they are in diff positions with possibly different velocities but we will begin our interest in both at what can be called t = 0s. Then, later on, they will have traveled the same amount of time when they are at the same position. So variables begin to fall out and we can solve for v for both objects.
So equations?
Moderator's note:
Please let the OP respond to pgardn's post -- to write the kinematic equations for uniformly accelerated motion, and put some more thought into working out the problem -- before providing further help.
(Two posts that provided equations have been deleted from this thread.)
Redbelly98
Physics Forums Mentor
1. How do you calculate the speed of a car passing a train?
The speed of the car passing a train can be calculated by dividing the distance traveled by the time taken. In this case, the car is traveling at a speed of 49 meters per second.
2. Is the car's speed affected by the train's speed?
Yes, the car's speed is affected by the train's speed. The relative speed between the car and the train will determine the car's speed when passing the train. For example, if the train is traveling at a speed of 30 m/s in the same direction as the car, the car's speed will be 19 m/s (49 m/s - 30 m/s).
3. What is the distance between the car and the train when the car passes it?
The distance between the car and the train when the car passes it is not provided in the given information. The distance can be calculated by multiplying the speed of the car (49 m/s) by the time taken to pass the train. For example, if it takes the car 5 seconds to pass the train, the distance between them would be 245 meters (49 m/s x 5 s).
4. Can the car pass the train at a different speed?
Yes, the car can pass the train at a different speed depending on the relative speed between the car and the train. If the train is traveling at a different speed or in the opposite direction, the car's speed when passing it will also be different.
5. How does the speed of the car affect its distance traveled when passing a train?
The speed of the car affects its distance traveled when passing a train. The faster the car is traveling, the shorter the distance it will take to pass the train. This is because the time taken to pass the train will be shorter at a higher speed, resulting in a shorter distance traveled.
