Transfer-Function: Vout/Vin
  1. Feb 24, 2014 #1
    Transfer-Function: "Vout/Vin"
    https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash3/t1/1656161_10151902951360919_2042068460_n.jpg
    2. Relevant equations
    https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn1/t1/16672_10151902951355919_965456274_n.jpg
    3. The attempt at a solution
    "Answer #1: Calculation Of Vout/Vin"
    The very last equation is my answer. Am I correct?
    https://scontent-a.xx.fbcdn.net/hphotos-ash3/t1/1969246_10151902957535919_1007404817_n.jpg
    "Answer #2: Display of log amplitude vs. log frequency"
    Does this diagram give what was asked for?
    https://scontent-a.xx.fbcdn.net/hphotos-frc1/t1/1958500_10151902957555919_1931978744_n.jpg
    "Answer #3: phase shift vs. log frequency"
    https://scontent-a.xx.fbcdn.net/hphotos-ash3/t1/1901948_10151902957540919_851749761_n.jpg
    Did I answer everything about this high-pass filter?
    Thank you
  3. Feb 24, 2014 #2
    berkeman
    Staff: Mentor
    The answers look fine. How did you make the Bode plot diagrams?
  4. Feb 25, 2014 #3
    FOIWATER
    It looks to be a picture, since it is slightly transparent you can see the next page through it.
    I guess it was more of a 'match the bode plot to the circuit' type of question?
  5. Mar 17, 2014 #4
    FOIWATER,
    This is a whole problem. Can you please look at all eight questions and answers and tell me if you see errors?
    Thank you for any help that you can offer.
    Did I answer all of the questions correctly and thoroughly? Can you please find any errors, and point them out to me so that I can fix them?
    Calculate the input impedance looking directly into the base of the BJT
    Calculate the output impedance including the 3.3k resistor
    Calculate VB neglecting loading of the bias network by the BJT
    Calculate VE neglecting loading of the bias network by the BJT
    Calculate IE neglecting loading of the bias network by the BJT
    Calculate VB including loading of the bias network by the BJT
    Calculate VE including loading of the bias network by the BJT
    Calculate IE including loading of the bias network by the BJT
    https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-frc1/t1.0-9/1932404_10151940102460919_638617745_n.jpg
    1(a): Calculate the input impedance looking directly into the base of the BJT
    Zin = (hFE + 1){ZLoad}
    Zin = (hFE + 1){R10k
    Zin = (100 + 1){10 x 10^3(ohms)}
    Zin = (101){10 x 10^3(ohms)}
    Zin = {10.1 x 10^5(ohms)}
    Zin = {1010k(ohms)}
    1(b): Calculate the output impedance including the 3.3k resistor
    Iin = [IB + (hFE)(IB)]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
    Iin = [(hFE + 1)(Ib)]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
    Ib = [(Vin)/(Rb)]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
    Iin = [(hFE + 1){(Vin)/(Rb)}]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
    Zout = {(Vin)/(Iin)}{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
    Zout = (Vin)/[(hFE + 1){(Vin)/(Rb)}]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
    Zout = {(Rb)/(hFE + 1)}{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
    Zout = {(10k)/(100 + 1)}{3.3k}/{(10k)/(100 + 1)} + {3.3k}
    Zout = 96(ohms)
    https://scontent-a-pao.xx.fbcdn.net/hphotos-prn1/t1.0-9/1964785_10151940672820919_881396491_n.jpg
    2(a): Calculate VB including loading of the bias network by the BJT
    rin = (hFE + 1){R}
    rin = (hFE + 1){R7.5k
    rin = (100 + 1){7.5 x 10^3(ohms)}
    rin = (101){7.5 x 10^3(ohms)}
    rin = {7.575 x 10^5(ohms)}
    rin = {757.5k(ohms)}
    IB = IE/(hFE + 1)
    IB = {(VCC/R7.5k)/(hFE + 1)}
    IB = {(15V/7.5k/(100 + 1)}
    IB = 1.98 x 10^-5
    IB = 19.8uA
    VB = (rin)(IB)
    VB = (757.5k)(19.8uA)
    VB = 15V
    2(b): Calculate VE including loading of the bias network by the BJT
    VE = VB - VBE
    VE = 15V - 0.6V
    VE = 14.4V
    2(C): Calculate IE including loading of the bias network by the BJT
    IE = IE/R7.5k
    IE = 14.4V/7.5k
    IE = 1.92mA
    2(D): Calculate VB neglecting loading of the bias network by the BJT
    {R150k/(R150k + R130k)} x VCC = VB
    150k/(150k + 130k) x 15V = VB
    8.03V = VB
    2(E): Calculate VE neglecting loading of the bias network by the BJT
    VE = VB - VBE
    VE = 8.03V - 0.6V
    VE = 7.43V
    2(F): Calculate IE neglecting loading of the bias network by the BJT
    IE = IE/R7.5k
    IE = 7.43V/7.5k
    IE = 0.99mA
    Are there any errors?
    Thanks again for your help.
  6. Mar 18, 2014 #5
    You made many mistakes in your answers
    Are you sure that RL = 10K?
    Very interesting VB = 15V?? Are you training to say that voltage divider magically disappeared?
    It seems that you completely don't understand what this loading effect of the bias network by the BJT means.
    If you remove BJT from the circuit this two 130k and 150K resistors form a unloaded voltage divider. But in your circuit the base current is loading our voltage divider. Simply you must include the base current in your calculation. Because now upper resistor provide current for the lower resistor and for the base. All you need here is to use KVL,KCL and maybe a Thevenine.
  7. Mar 18, 2014 #6
    I do not know how to calculate for BJT's
    I think now, that the RL = 3.3k
    I thought 15V was strange myself,
    I don't know how to use KCL, or KVL on a transistor.
  8. Mar 18, 2014 #7
    Which answers have errors? I would like to fix them
  9. Mar 18, 2014 #8
    1a, 2a, 2b, 2c, are all wrong.
    You do KVL and KCL exactly the same as for normal circuit with resistors and sources.
    You simply treat Vbe as voltage source equal to 0.6V. And remember that KCL for BJT
    Ie = Ib + Ic; and Ic = Ib*β (you treat the transistor as CCCS) that's all.
    For example for this circuit
    Vcc = Ib*Rb + Vbe + Ie*Re and since Ie = Ib + Ic = Ib + Ib*β = Ib*(β + 1)
    So we have
    Vcc = Ib*Rb + Vbe + Ib*(β + 1)*Re and simply solve for Ib
      File size:
      1.9 KB
      275
  10. Mar 18, 2014 #9
    Thanks Jony130,
    you're a big help, I am going to calculate values based on your advice, and I will respond.
    Thank you
Have something to add?
Draft saved Draft deleted
Similar Discussions: Transfer-Function: Vout/Vin
  1. Transfer Function (Replies: 3)
  2. Transfer Function (Replies: 8)
  3. Transfer Function (Replies: 20)
Loading...
