Transfer of Force on a Lathe
  1. May 15, 2015 #1
    If I mount an unbalanced piece of wood on my lathe, it causes vibration. i.e. I'm spinning an offset mass at a high rate of speed. If I add weight to the base of the lathe (e.g. sand bags, concrete blocks, bolting it to the floor), I can stop the vibration. My question is, where is the force transferred? Am I causing the lathe components, bearings, ect to accept the force? Or is the force absorbed by the extra weight (or the floor)?
  3. May 15, 2015 #2
    phinds
    You are causing the lathe components to accept the force, but that's a GOOD thing because you are avoiding shaking them to pieces. It's much better for them to work vibration-free. The extra force is being applied in a much more uniform way than when the lathe is vibrating.
    Check this out:
    http://www.hobbithouseinc.com/personal/woodpics/
  4. May 15, 2015 #3
    So assuming that overall the lathe is initially designed to operate safely under specific loads, I wonder if by adding the weight one is moving out of the range specified design. Also, I wonder if the user is causing excessive wear on the components? I think I need a diagram of where the forces go.
  5. May 15, 2015 #4
    phinds
    I believe most lathes are designed to have stabilizing weight added to the base. Certainly it's something most every lathe owner does, unless he/she has a powerful lathe and only does modest turnings. Some of the bigger semi-professional lathes are so heavy they don't need it.
