Homework Help: Transfer of torque
  1. Sep 16, 2009 #1
    The clutch system shown in Fig. P10-22 is used to transmit torque through a 3-mm-thick oil film with [tex]\mu = 0.38 N \bullet s/m^{2}[/tex] between two identical 30-cm-diameter disks. When the driving shaft rotates at a speed of 1450 rpm, the driven shaft is observed to rotate at 1398 rpm. Assuming a linear velocity profile for the oil film, determine the transmitted torque.
    2. Relevant equations
    [tex]T = \mu\left(\frac{4\pi^{2}R^{3}\dot{n}L}{l}\right)[/tex]
    3. The attempt at a solution
    [tex]L = 30cm = 0.3m[/tex]
    [tex]l = 3mm = 0.003m[/tex]
    This is where I am stuck I am not sure what R is. I think I have to find T for the two rpms and find the difference between them for the transferred torque.
  3. Sep 17, 2009 #2
    The units should tell you what R is. You have to get N-m out of this equation, so based on what you know (the given values) you can figure out what unit R will have and that will tell you what it's value should be.
    Thanks
    Matt
