• Support PF! Buy your school textbooks, materials and every day products Here!
Transformation fun!
  • Thread starter Calixto
Describe a sequence of transformations that would transform the graph of
y = 5cos3x into y = cos(3x + 6)
Answers and Replies
458
The 5 in front of the cos(3x) (I assume it's cos(3x), be more clear next time) turned into a 1 in the second function. What does this mean?
The (3x) turned into a (3x + 6). What does this mean?
Recall the definitions of translations and expansions/compressions.
1,631
Remember that:
Let f(x), ang g(x), be two functions. Then if g(x)=f(x)+k, it means that g(x) is simply the function f(x) shifted up/down wards for k units.
g(x)=f(x+k), it means that g(x) is simply the function f(x) shifted horizontally for k units, either to the right or to the left, depending on the sign of the constant k.
g(x)=kf(x), it means that g is simply the function f, shrinked or extended(or how do you say it) vertically, depending whether |k|>1, or |k|<1.
g(x)=f(kx), is again the function f either extended, or shrinked horizontally, depending on the value of the constant k.
I hope this helps a lill bit.
HallsofIvy
41,738
897
Remember that any change before the given function is applied (in this case 5cos(3x)) is a change in x and any function after the function is a change in y.
changing 5cos(3x) to cos(3x+6) involves 3 changes:
1) Add 6 to 3x. That is, change 3x to 3x+ 6= 3(x+2) or x to (x+ 2). That's the first transformation.
2) change y= cos(3x+6) to y= 5cos(3x+6) or y to 5y. That's the second transformation.
Related Threads for: Transformation fun!
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
