1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Transformation Matrix issue
  1. Nov 18, 2009 #1
    Find m(DT), that is, find the matrix for the transformation DT where D is the derivative operator and T: V -> V , T(p(x)) = xp'(x).
    The polynomial is of degree <= 3, and the basis for it is (1,x,x^2, x^3).
    2. Relevant equations
    Basic matrix multiplication needs to be understood.
    3. The attempt at a solution
    I have DT(1,x,x^2,x^3) -> D((0,x,2x^2,3x^3)) -> (0, 1, 4x, 9x^2).
    So I form my matrix by solving the following:
    M*[1, x, x^2, x^3] = [0, 1, 4x, 9x^2].
    I get that the matrix is 4x4, of course, and is defined by row-vectors as follows:
    [0,0,0,0], [0,1,0,0], [0,0,4,0], [0,0,0,9].
    As you see, that matrix does take (1,x,x^2,x^3) -> (0,1,4x,9x^2).
    The book; however, says that the transformation matrix is the following, defined by row vectors: [0,1,0,0], [0,0,4,0], [0,0,0,9], [0,0,0,0].
    I can't see how that gives the right answer.
    What am I doing wrong here?
  3. Nov 18, 2009 #2
    Hurkyl
    Staff Emeritus
    Your notation is... peculiar. I think all you need to do is pay more care to what you write really means.
    DT(1,x,x^2,x^3) -> D((0,x,2x^2,3x^3)) -> (0, 1, 4x, 9x^2)​
    What did you really mean by this? Is this just shorthand for the four equations
    DT(1) = 0
    DT(x) = 1
    DT(x^2) = 4x
    DT(x^3) = 9x^2​
    or did you mean something else?
    M*[1, x, x^2, x^3]​
    This doesn't make sense -- it would be the matrix product of a 4x4 array of scalars with a 1x4 array of vectors....
  4. Nov 18, 2009 #3
    I meant that [1,x,x^2,x^3] is a column-vector, so it would look like
    |1|
    |x|
    |x^2|
    |x^3|
    M multiplying that, so it would be 4x4 matrix times a 4x1 amatrix, to give out a 4x1 matrix.
  5. Nov 18, 2009 #4
    D H
    Staff Emeritus
    You shouldn't have any xs in those vectors. The basis for your space is 1, x, x2, and x3. The various powers of x come from the basis, not the vectors. For example, the vector that corresponds to the polynomial 1+x+x2+x3 is simply [1,1,1,1].
  6. Nov 18, 2009 #5
    So then I should be showing that D(T([1,1,1,1])) -> [0,1,4,9] ? Wouldn't this still have the same problem as before? Can I not consider these as column vectors? Maybe that's the issue.
  7. Nov 18, 2009 #6
    D H
    Staff Emeritus
    No, you should be showing that D(T([1,1,1,1])) -> [1,4,9,0].
  8. Nov 18, 2009 #7
    Oh, alright, well if I have DT([1,1,1,1]) = [1,4,9,0] then that would be
    the matrix would be
    [1,0,0,0]
    [0,4,0,0]
    [0,0,9,0]
    [0,0,0,0]
    As [1,0,0,0]*[1,1,1,1] = [1] (corresponding to 0 degree poly)
    [0,4,0,0]*[1,1,1,1] = [4] (corresponding to x)
    [0,0,9,0]*[1,1,1,1] = [9] (corresponding to x^2)
    [0,0,0,0]*[1,1,1,1] = [0] (corresponding to x^3)
    That matrix still isn't what is in the book. But the matrix that is in the book would work fine as well, so how would I decide on which matrix to use?
    Is there a more natural way to go about this? (I've already done this homework and turned it in for a grade, I am just using this problem to study for a test, so presenting methods to solve it will not be giving me an unfair advantage over other students grade wise).
    -Ian
  9. Nov 18, 2009 #8
    D H
    Staff Emeritus
    The problem here is you are not using a general third order polynomial. The vector corresponding to [itex]a+bx+cx^2+dx^3[/itex] is [a,b,c,d]. What is T(p(x))? D(T(p(x)))?
Similar Discussions: Transformation Matrix issue
  1. A matrix issue (Replies: 1)
  2. Matrix Transformations (Replies: 2)
  3. Matrix transformation (Replies: 1)
  4. The matrix transform (Replies: 2)
Loading...
