Transformations of functions
  1. Jan 31, 2012 #1
    Okay so I've done very well in college so far, and I thought I was at least decent at math, but I just started this precalculus class and I'm having an issue.
    I basically don't know, and can't get a straight answer about how to handle functions that have multiple transformations going on. This is not a homework question, but it is a perfect example of my issue, so I'm posting it.
    My answer is the function sketched below and to the left of the printed one, except I would have shifted it down one but there is no room on the graph, as you can see. I must be that far off, huh? The teacher's answer is like mine but shifted up one unit. This is apparently because he reflected it after shifting, while I reflected first. In his email explaining why he did this he told me "It's always best to do the reflecting last as it is the last thing that happended to the function in the transformation process." WHAT???
    How do I know the order, what do I DO? Please someone help me.
  3. Jan 31, 2012 #2
    I believe your teacher is wrong, and you are correct (unless I'm suffering from brain failure).
    In the case of y= -f(x+2) -1 you must "reflect" f(x+2) before subtracting 1! This graph should be 1 below y= -f(x+2)!
    If it was y= - [f(x+2) -1] you would "reflect" afterwords like your teacher did (ultimately shifting up 1, because y = - [f(x+2) -1] = -f(x+2) + 1).
  4. Jan 31, 2012 #3
    Cool, I thought I was right. But can you explain how I determine the order to do the transformations in general?
  5. Feb 6, 2012 #4
    Sorry, didn't see your reply until today. There is a specific order of operations, with a few different rules to get used to.
    For functions (such as f(x) or g(x)), you apply the function to whatever is within the parenthesis in the function declaration.
    f(x) you apply the function f to x
    f(x+2) you apply the function f to x+2. in other words you replace the value for x with x+2
    IF f(x) = 2x THEN f(x+2) = 2(x+2)
    IF f(x) = 2x+1 THEN f(x+2) = 2(x+2) + 1 etc.
    Then you follow the standard order of operations.
    IF y=f(x) + 1 you calculate f(x) then add in 1 to calculate y.
    IF y=-f(x) + 1 you calculate -f(x) then add in 1 to calculate y.
    IF y=-[f(x) + 1] you calculate f(x), add in 1, and THEN flip the sign to determine your y value.
Loading...
