Transformer Impedance/Ratio
  1. Jun 24, 2009 #1
    See attached for a view of the problem
    Variables a=transformation ratio= 1/5
    Ip=2Amps
    ZL=2 ohm resistor
    2. Relevant equations
    Q1 : Find the current magnitude of the current IL and the Voltage VL
    Q2 : Find the input impedence.
    3. The attempt at a solution
    OK, my question is variable a, which is the transformation ratio is 1/5. From my reading the transformation ratio is equal to the number of turns of the primary divided by the number turns of the secondary...
    How
    so a= NP/NS = 1/5
    NP =1 turn Per NS =5
    Then, the input impedence should be Rin = A^2ZL
    Rin = (1/5)^2(2 ohms)
    Rin = .08 ohms
    Does that look correct for the impedance?
    Then for the current for IL, a = Is/Ip or Is = (a)(Ip) or Is = .4 amps
    does it look correct?
    Thanks for any response :)
  3. Jun 24, 2009 #2
    negitron
    Yes, these figures look correct. You should be able to readily calculate VL now.
  4. Jun 24, 2009 #3
    Awesome :) thanks for your response :)
Similar Discussions: Transformer Impedance/Ratio
  1. Impedance ? (Replies: 5)
Loading...
