Transistor which has Ic=2.5ma
  • Thread starter amaresh92
  • Tags
    Transistor
In summary: So, in summary, when calculating the beta DC for a transistor with known values of Ic and Ib, you can use either formula 2 or formula 3, but be careful when rounding up the result for alpha DC, as it may affect the final result for beta DC.
amaresh92
163
1. Homework Statement [/b]
calculate alpha DC (emitter to collector dc current gain) and beta DC (base to collector dc current gain) for a transistor which has Ic=2.5ma, Ie=2.6ma .
formula 1) alpha DC=Ic/Ie.
formula 2) beta DC =Ic/Ib.
formula 3) beta DC = alpha DC/(1-alpha DC)
formula 4) Ib=Ie-Ic
using formula 1)
alpha dc=Ic/Ie
=2.5/2.6
=0.96
using formula 4)
Ib=Ie-Ic
=2.6-2.5
=0.1ma using formula 2)
beta DC =Ic/Ib
=2.5/0.1
=25
using formula 3)
= 0.96/(1-0.96)
=24
my doubt is, from above calculation for beta DC using formula 2 and 3 we are getting two different values for beta DC. so which one is correct and under which condition or how i should use these two formula? In the sense when i should use formula 2 and formula 3.
advanced thanks
The two formulas 2 and 3 can be proved easily that they are equal as long as we accept that the formulas 1 and 4 are valid and true.
BUT you get different results because you rounded up the result for alphaDC (alphaDC is not exactly 0.96 , if you use more decimal digits like 0.961538 you ll get betaDC closer to 25).
So be carefull when you round up results, or choose the formula that doesn't use rounded results. In this example formula 2 doesn't use rounded results because you know the exact values for Ib and Ic.
1. What is a transistor?
A transistor is a semiconductor device that is used to amplify or switch electronic signals. It is made up of three layers of material - the collector, the base, and the emitter - and is commonly used in electronic devices such as computers, televisions, and radios.
2. What does Ic=2.5ma mean?
Ic=2.5ma refers to the collector current of the transistor, which is the amount of current flowing through the collector terminal. In this case, it is equal to 2.5 milliamperes, or 0.0025 amperes.
3. Why is Ic=2.5ma important?
The collector current is an important parameter of a transistor as it determines the amount of current that can be amplified or switched by the device. A higher Ic value means a transistor can handle more current, making it suitable for use in circuits that require higher currents.
4. What factors affect Ic=2.5ma?
The collector current of a transistor can be affected by various factors such as the voltage applied to the base, the type of material used in the transistor, and the temperature. For example, increasing the base voltage can result in a higher collector current.
5. Can the value of Ic=2.5ma be changed?
Yes, the value of Ic can be changed by adjusting the circuit components or by using a different type of transistor. For example, a transistor with a higher gain (amplification factor) may have a higher Ic value, while a transistor with a lower gain may have a lower Ic value.
