Transistors and Diode Test
In summary: However, I would think that there would be little use for a device that only operates in one of three modes.
TFM
1,026
Explain why the BC junction will give a smaller voltage drop, and will thus have a higher voltage measured then a BE Junction.
N/A
Okay, hopefully this is the right section to post this in. See, I have read the book, 'The Art of Electronics', and from this I seemed to have gathered the following:
'The difference in voltages occurs because the BC requires more energy, because it is flowing anti-biased, whilst the BE will be conductive, and allows the current to flow more easily,'
However, what I wrote seems to go against the above, it would indicate that the BE should have the smaller drop/higher voltage measured?
Thanks,
TFM
Look at the equation for the built-in potential barrier [tex]V_{bi}[/tex]. That's all you need to answer this question.
Does it have any other names, because I am looking through 'The Art of Electronics', and cannot find it in there? and this is a big book!
TFM
There isn't anything like that on the transistor section :bugeye:
This is a physics course, but this section, practical electronics, is more about cicuits. No mention of ions in the Transistor section?
TFM
? Are you sure about that? But surely that equation is present somewhere? The acceptor and donor ion concentrations refer to the concentration of acceptor and donor atoms in the doped semiconductor.
Pretty sure - the course really is about setting up circuits, despite being in a physics course, and the book is for electronics students really.
The Art of Electronics is a good reference / review book (or for getting up and running with practical--and simpler electronics), but not so great for really learning about semiconductor operation. Try Solid State Electronic Devices (Streetman and Bannerjee) or Microelectronic Circuits (Sedra and Smith)--generic EE semiconductor physics and active device books, for a better introduction.
Then again, the answer to your problem is (partially) answered at the Wikipedia page on BJTs under structure (along with what Defennder says):
http://en.wikipedia.org/wiki/Bjt#Structure
Looking at Wikipedia, is this a useful reference:
The bipolar junction transistor, unlike other transistors, is usually not a symmetrical device. This means that interchanging the collector and the emitter makes the transistor leave the forward active mode and start to operate in reverse mode. Because the transistor's internal structure is usually optimized to forward-mode operation, interchanging the collector and the emitter makes the values of α and β in reverse operation much smaller than those found in forward operation; often the α of the reverse mode is lower than 0.5. The lack of symmetry is primarily due to the doping ratios of the emitter and the collector. The emitter is heavily doped, while the collector is lightly doped, allowing a large reverse bias voltage to be applied before the collector–base junction breaks down. The collector–base junction is reverse biased in normal operation. The reason the emitter is heavily doped is to increase the emitter injection efficiency: the ratio of carriers injected by the emitter to those injected by the base. For high current gain, most of the carriers injected into the emitter–base junction must come from the emitter.
Looks useful,
TFM
Yes it looks correct to my knowledge. Except I don't know enough to verify that "a of the reverse mode is lower than 0.5". Clearly the bulk of semiconductor device physics focuses on the forward active region of the BJT so I didn't study the three other less used modes.
What are transistors and diode tests?
Transistors and diode tests are electronic tests used to check the functionality and characteristics of transistors and diodes. These tests are commonly performed by scientists and engineers in the field of electronics to ensure the proper functioning of these components in electronic circuits.
Why are transistors and diode tests important?
Transistors and diodes are essential components in electronic circuits, and it is important to ensure their proper functioning for the overall functionality of the circuit. These tests help in identifying any defects or faults in the components, allowing for early detection and prevention of potential failures.
How do transistors and diode tests work?
Transistors and diode tests work by applying a specific voltage or current to the component and measuring the resulting voltage or current. This allows for the determination of the component's characteristics, such as its forward voltage drop, leakage current, and breakdown voltage.
What are the different types of transistors and diode tests?
There are several types of transistors and diode tests, including the DC test, AC test, and sweep test. The DC test involves applying a constant voltage or current to the component, while the AC test involves applying an alternating current or voltage. The sweep test involves varying the voltage or current over a range to determine the component's characteristics.
Can transistors and diode tests be performed on all types of components?
No, transistors and diode tests can only be performed on components that have semiconductor properties, such as transistors and diodes. These tests cannot be performed on non-semiconductor components, such as resistors and capacitors.
