Transmission line matching
634
In high speed digital designs, there is a series terminating resistor to match the output impedance of the driver IC with the transmission line on the PCB. Some think the purpose of this resistor is to decrease the drive of the IC.
How do I convince them its not to decrease the (current) drive but to match the impedance?
1,675
Teach them transmission line theory.
Actually it's not there to match the impedance of the output of the driving IC but the impedance of the lines on the board.
sophiecentaur
3,868
I guess you could tell them about the effects of echos on pulse shape and inter-symbol interference. Also about the 0.4m per nanosecond speed of signals on transmissions lines.
sophiecentaur
3,868
More like 0.2m per nanosecond, actually.
634
This would be too much to digest.
634
The question I am struggling with is - why do reflection only occur when the tx line approaches signal wavelength.
Why doesn't this occur at wave length >> tx line.
I'm not able to come up with a good explanation.
1,744
50
Reflections do occur when transmission lines are shorter than a wavelength it's just that when the time of reflection is less than a cycle, the echo isn't perceived so much as an echo but as a change in impedance of the load. For instance, if a transmission line is 1/4 wavelength and is left unterminated (open) the signal will travel 1/4 wavelength, bounce off the open, and reflect back to the source 180 deg out of phase with the transmitted signal. To the source it appears the load is a short not an open.
In testing RF amplifiers we frequently used stretch lines (or trombone lines) with a short on the end to determine if there were instabilities at any reflection phase angles.
Related Threads for: Transmission line matching
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
