Anabelle37
- 39
Use a shell balance method to derive the equation governing the two dimensional temperature distribution,u, in a circular disk in polar coordinate system(r,theta). allow for the possibility of differing thermal conductivities in the r and theta directions.
fouriers law in the theta direction of a cylinderical coordinate system is qtheta=-ktheta*(1/r)*(du/dtheta)
I know I have to begin with a shell balance: heat in - heat out + generation = accumulation
I have assumed that its steady state with no generation of heat.
shell balance: (rate of heat flow in at r) - (rate of heat flow out at dr) + (rate of heat flow in at theta) - (rate of heat flow out at rdtheta) = 0
does this seem right so far??
so when i actually write equations for the rate of heat flow = area x heat flow, q
what is the area since is only a circular disk? Can i not use surface area?
