Treadmill Physics: Understanding Incline & Work Done
  • Thread starter TimR
  • Tags
    Physics
In summary, the incline of a treadmill has no affect on the amount of work that is done. However, if you are on a treadmill and the machine is stopped, then the amount of work that is done is based on how hard you are pedaling.
TimR
Ok, I think I've confused myself. :-S
How can the incline of a treadmill have any affect on the work done? Surely as there is no actual change in height, there is no change in potential energy and so no significant amount of extra work is done. Why then do treadmills even allow you to change the incline and why have I found equations that involve the supposed change in height? Do you see why i am confused?
Thanks
-Tim
An excellent question! It's easy to see where the confusion arises.
When you're on a treadmill, you are changing your height. Every step you take forwards, you essentially also take upwards, depending on the elevation of the treadmill. The fact that you're (quickly) returned to where you started is irrelevant. This means that a steeper setting will indeed be more difficult, and explains why a gravitational potential term is included in your energy equations.
If, instead of running, you were cycling on the treadmill (and actually could stay in the same place) then the above would not apply.
Let us know if you don't understand, my explanations have been a bit off lately!
Ooh, and also, welcome.
No, consider what the situation would be like if the treadmill were stopped: the bike would roll down backwards. It takes a force on the pedals to keep the bike stationary in a stopped treadmill, and therefore extra energy when it is moving.
Likewise with the running - you can stay exactly in the same place and still use more energy: since the treadmill is falling away from you, you have to push harder to stay in the same place.
Or consider the extreme case where the treadmill is vertical. Then it's like a ladder, which as you climb, is lowered so you stay in the same place. You definitely have to apply a force of your own weight, and with arms and legs moving while applying this force, you definitely do work. Where does this energy appear? It is in the brake mechanism that allows the ladder to descend while you remain in place. It is similar to treading water while swimming: you stay in place, but definitely do work; that work appears and is dissipated in the water. Similarly, getting back to the treadmill, you will find that there is something, a brake of some kind, that is built into the mechanism that takes up the energy. Instead of a brake, you could hook up a generator and have your work turned into electricity.
Russ 1, brewnog 0. Thanks for that. :smile:
1. How does the incline of a treadmill affect the amount of work done?
The incline of a treadmill increases the amount of work done by increasing the distance the user has to travel. This is because the incline adds an additional vertical component to the movement, increasing the overall distance the user must cover to complete a certain distance.
2. How does the speed of a treadmill affect the amount of work done?
The speed of a treadmill affects the amount of work done by increasing the rate at which the user is covering a certain distance. This means that a higher speed will result in a greater amount of work being done in a shorter amount of time.
3. What is the relationship between the incline and speed of a treadmill in terms of work done?
The relationship between the incline and speed of a treadmill in terms of work done can be described by the formula W = mgh, where W is the work done, m is the mass of the user, g is the acceleration due to gravity, and h is the height gained by the incline. This means that both the incline and speed contribute to the overall work done.
4. How does the weight of the user affect the work done on a treadmill?
The weight of the user affects the work done on a treadmill by increasing the amount of force required to move the body against gravity. This means that a heavier user will require more work to be done in order to cover the same distance as a lighter user.
5. Can the work done on a treadmill be calculated?
Yes, the work done on a treadmill can be calculated by using the formula W = mgh, where W is the work done, m is the mass of the user, g is the acceleration due to gravity, and h is the height gained by the incline. By knowing the values of these variables, the work done on a treadmill can be accurately calculated.
  • Classical Physics
12K
  • Classical Physics
  • Classical Physics
