Trebuchet help!
  • Thread starter steve092
Trebuchet help: Calculating velocity
I'm new to this site, so bear with me!
OK, so I'm doing a trebuchet for my physics project. I have done three trials with counterweights of different masses. I have all of the distances that a golf ball of mass=0.045kg has traveled. I also have the masses of the counterweights.
Just as a starting point for the first trial:
mass of the counterweight=10.937
h=0.631m
The average distance for this trial was 34.33m.
2. Relevant equations
PEg=mgh
KE=(1/2)mv2
3. The attempt at a solution
I've done the calculations; however, my answers were nowhere near what the velocity should be. For one trial, the mass of the counterweight was 10.937kg. I did the calculations and the velocity came out to be 3.53m/s which seemed a little slow.
Obviously, I'm doing something wrong. I wonder if it is because the mass of the golf ball needs to be taken into account somehow??? Anyways, thanks in advance!
I've used the example from https://www.physicsforums.com/showthread.php?t=250335&highlight=trebuchet and I still can't get it. I don't even understand how the answer was calculated in that example.
Well, I think I might have it! I used that example in the post I linked to in the previous post, and I just changed the values to fit my case. I did the other example to get the right answer that was provided. So, I'm assuming that my answer is correct
Here are the givens:
m1=10.937
m2=.045
h1=.076
h2=.838
I used:
m1gh1-m2gh2=(1/2)m1v12+(1/2)m2v22
And I used the proportion:
v1 .076
v2 .838
And just solved for v2.
My final answer was 10.742 m/s which sounds correct, but I'd like to see if I made any mistakes.
That proportion I used, v1/v2= 0.076/0.838, what exactly is that?
OK, I think that solved for velocity correctly. Using the calculated velocity and the average distance traveled of the golf balls in a trial, I calculated a time of about 3.3 seconds. When I launched golf balls and manually timed it, the results were close enough.
Want to reply to this thread?
"Trebuchet help!" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
