Triangle Inequality Proof theorem
In summary, the conversation discusses the Triangle Inequality and the Cauchy-Schwarz inequality, which states that a^2+2ab+b^2 is less than or equal to |a|^2+2|a||b|+|b|^2. The speaker questions the rigor behind this inequality and suggests that it is intuitively obvious. They also mention the use of calculus in proving this inequality. The expert summarizer explains that the Cauchy-Schwarz inequality can be proven using simple algebra and that it is only necessary to show that ab is less than or equal to |a||b|.
Howers
447
To make it clear, I understand the theorem and several proofs of this theorem but the most basic one is not making sense.
Thm: |a+b|<or=|a|+|b|
Proof:
(a+b)^2 = a^2+2ab+b^2 < or = |a|^2 + 2|a||b|+|b|^2 = (|a| + |b|)^2
Taking the square root of both sides and remember that |x|=square root of (x^2), we can prove that |a+b| < or = |a| + |b| (Triangle inequality)
MY QUESTION: Why can you say that a^2+2ab+b^2 < or = |a|^2 + 2|a||b|+|b|^2 is true? Intuitively, this makes sense because if a or b is negative then obviously their product will make the left side less. But using this logic, why not just say that the triangle inequality is likewise intuitevly obvious? Obviously if one is negative, their sum must be less. So my question is, how do you rigoursly conclude ab<or=|a||b|.
This is the Cauchy inequality, but because it requires calculus to prove it does not seem logical as calculus relies on this very inequality!
Mathematics news on Phys.org
Well trivially x2=|x|2 for all x. So to show that a^2+2ab+b^2 is less than or equal to |a|^2+2|a||b|+|b|^2, you really only need to show that ab is less than or equal to |a||b|, you will have three cases, both are positive, both are negative, or one of a and b is negative.
Cauchy-Schwarz does not require calculus to prove.
What is the Triangle Inequality Proof theorem?
The Triangle Inequality Proof theorem states that the sum of any two sides of a triangle must be greater than the third side.
What is the importance of the Triangle Inequality Proof theorem?
The Triangle Inequality Proof theorem is important because it helps us determine if a given set of three sides can form a triangle or not. It also helps in proving various properties and theorems related to triangles.
How do you prove the Triangle Inequality Proof theorem?
The Triangle Inequality Proof theorem can be proved using the triangle inequality property, which states that the length of any side of a triangle must be less than the sum of the lengths of the other two sides. This property can be proved using the Euclidean geometry axioms and other basic geometric principles.
What are some real-world applications of the Triangle Inequality Proof theorem?
The Triangle Inequality Proof theorem has many real-world applications, such as in navigation and surveying, where it is used to determine the shortest path between two points. It is also used in computer graphics to ensure that the edges of a triangle do not intersect. In addition, the theorem is used in physics and engineering to analyze forces and vectors.
Is the Triangle Inequality Proof theorem applicable to all types of triangles?
Yes, the Triangle Inequality Proof theorem is applicable to all types of triangles, including equilateral, isosceles, and scalene triangles. It is a fundamental property of triangles and applies to all three-sided polygons.
  • General Math
9K
  • General Math
  • General Math
9K
