Triangle Inequality: Solving |z^2+3| ≤ (12) for |z|=3
In summary, using the triangle inequality, it can be shown that \left|z^2+3\right| \leq (12) for \left|z\right|=3, where z is a complex number. This can be done by substituting z1 with z^2 and z2 with 3, and then using the fact that |z^2|=|z|^2. A similar question is given where it must be shown that \left|z^2(2+i)+1\right| \geq 1 for \left|z\right|=1, and this can be done by using the property that |xy|=|x||y| and evaluating the absolute values to obtain the
sara_87
763
Use the triangle inequality to show:
[tex]\left|z^2+3\right|[/tex] [tex]\leq(12)[/tex] for [tex]\left|z\right|[/tex]=3
triangle inequality: [tex]\left|z_1+z_2\right|[/tex][tex]\leq[/tex] [tex]\left|z_1\right|[/tex]+[tex]\left|z_2\right|[/tex]
I understand the triangle inequality but i can't seem to do the question.
Simply substitute z1 with z^2 and z2 with 3.
but how do i use the information: 'on abs(z)=3' ?
oh i see:
like this:
[tex]\left|z^2+3\right|[/tex][tex]\leq[/tex][tex]\left|z^2\right|[/tex]+[tex]\left|3\right|[/tex]
[tex]\left|z^2+3\right|[/tex][tex]\leq[/tex]9+3=12
am i missing something?
Thats right. And note that |z^2|= |z|^2
thank you.
I'm working on a similar question but this time, i must show that:
[tex]\left|z^2(2+i)+1\right|[/tex] [tex]\geq[/tex] 1 for [tex]\left|z\right|[/tex]=1
this time we can use the triangle inequality:
[tex]\left|z_1-z_2\right|[/tex] [tex]\geq[/tex] [tex]\left|abs(z_1)-abs(z_2)\right|[/tex]
do i substitute: z1 with z2(2+i) and z2 with -1 ?
because when i do this, i get:
[tex]\left|z^2(2+i)+1\right|[/tex] [tex]\geq[/tex] [tex]\left|z^2(2+i)-1\right|\right|\left|[/tex]
I think I am making a mistake
Your substitution is correct, but evaluate the absolute values on the right hand side
after evaluating the absolute values, the right hand side would look like:
2z^2 +iz^2-1
so somehow i must show that this is 1
The absolute value a complex number a+ib is
Sqrt(a^2+b^2), and thus a real number. Further you know abs(z)=1. And further abs(xy) = abs(x)abs(y). See what you can do with that
oh right, thanks, so i will get:
right hand side:
abs(1*abs(2+i)-1)=abs(4+i^2-1)=abs(sqrt(3)-1)=sqrt(3+1)=2
?? not 1 ?
1. What is the Triangle Inequality?
The Triangle Inequality states that the sum of any two sides of a triangle must be greater than the length of the third side.
2. How is the Triangle Inequality used to solve equations?
The Triangle Inequality can be used to set up and solve equations involving absolute values. It helps us determine the range of possible values for a variable.
3. What does |z|=3 mean in this equation?
|z| represents the absolute value of the complex number z. In this equation, it means that the distance of z from the origin is 3.
4. How do you solve for z in this equation?
To solve for z in |z^2+3| ≤ (12) for |z|=3, we can rewrite the equation as |z^2+3| ≤ (12) as |z|^2+|3| ≤ (12). Using the properties of absolute value, we can then solve for z using the Quadratic Formula.
5. What is the final solution for this equation?
The final solution for |z^2+3| ≤ (12) for |z|=3 is z = -3, -2, 2, or 3.
