Question: How does the triboelectric effect produce electricity in generators?
  • Thread starter maryy
  • Tags
    Generators
In summary,recently i began reading about triboelectric effect and triboelectric generators(and/or triboelectric nanogenerators) but i really need somebody to explain me this.those generators produce the amount of energy mentioned in this pic just from the contact and separation of the layers?. like if i take the triboelectric generator that produce 98 watts per square meter and rub 1000 square cm of it with my palm and with sufficient pressure to make all the layers to contact each other i will produce 9.8 watts just from that simple rubbing motion?.Triboelectricity happens as a result of taking two different materials and rubbing them together. After rubbing, one
maryy
_progress_made_in_the_output_power_density_of_triboelectric_nanogenerators_within_12_months..tif.png
Triboelectricity happens as a result of taking two different materials and rubbing them together. After rubbing, one material gives up its electrons to the other material. This results in one material becoming negatively charged and the other becoming positively charged. When you separate the two you have something like a parallel plate capacitor which can then be used to produce power. I suppose this figure is showing the power densities through out the whole process, with the final state in the top right (i.e. your separated materials that mimic the capacitor).
Don't forget that regardless of the type of energy conversion, tiboelectric or otherwise, to make 10 watts of power, your hand has to provide somewhat more than 10 watts. That's a lot. The video below shows a squeeze flashlight that might make 1 watt. So think, 10 times that. It sounds pretty tiresome to me.
By the way, I learned a new word today triboelectric.
Likes billy_joule
other forms of energy conversions makes sense to me but what kind of energy triboelectricity actualy converts?, you can press piezoelectricity enough and produce electric current or move a dynamo and produce electric current but with triboelectric generator from what i understood all the current is produced from the contact and separation of layers.
does triboelectric generator are just somekind of piezoelectric generators that work with much less pressure?.
Nidum said:
Friction generators have been around for a long time and were used in the earliest researches into electrical science .
https://en.wikipedia.org/wiki/Electrostatic_generator
http://www.sparkmuseum.com/FRICTION.HTM
in the wiki article about nanogenerators there is an explenation(drawings) about "Vertical contact-separation mode of triboelectric nanogenerator"
https://en.wikipedia.org/wiki/Nanogenerator#Triboelectric_nanogenerator
and it doesn't look like there is much of a friction here.
anyway what is that "energy density" in the picture i posted?(that also presented in the wiki article) what exactly "98 W/square meter" means?
Energy Density = Power/Area. It is a metric that describes how good a power technology is. If you have 98 Watts/Square meter and you had 1 square meter of triboelectric material, you should expect 98 Watts of power. Or if you have 2 square meters of triboelectric material, you should expect 98 X 2 or 196 Watts of power.
BTW triboelectricity is not piezoelectricity. Piezoelectricity uses crystal like materials to generate power when they are subjected to stress, where as triboelectricity uses materials that are brought into contact to generate power.
but how does 98 watts are generated? from the friction generated by the pressure or just from the mere contact and separation of the layers?. what kind of energy does thos generators transform to electrical energy?. sorry for all my question but something here just really puzzles me
Come on. When we provide links to articles, we expect you to read the articles before asking more questions. The Wikipedia article on triboelectrics which was linked in #6 says in the very first sentence:
A triboelectric nanogenerator is an energy harvestingdevice that converts the external mechanical energy into electricity
i ALREADY readed that and i already asked "does triboelectric generator are just somekind of piezoelectric generators that work with much less pressure?" which means that i aware to that it uses mechanical energy.
the thing that confuses me is that "power density". like if i take a triboelectric generator with "98 watts per square meter" and press on it with my palm it will produce current for my palm's surface area or for the pressure i made on it with my palm? or both?.
I think the rubbing or friction aspect of triboelectricity can be misleading. The energy comes from contact and separation. The rubbing just brings material of different electronegativity into better contact with each other. The mechanical energy spent to overcome friction is wasted. Very little of it is converted to electrical energy.
Yes .
You can see what is going on much more clearly by looking at a school lab type belt and roller Van Der Graf generator . Generation of charge is by a continual contact - separation process .
@maryy - have a look here :
http://sciedwiki.pppl.wikispaces.ne...tor.pdf/209335520/Van de Graaff generator.pdf
1. What is a triboelectric generator?
A triboelectric generator is a type of energy harvesting device that converts mechanical energy into electrical energy using the triboelectric effect. This effect occurs when two different materials are brought into contact and then separated, resulting in the transfer of electrons between the materials and the generation of an electrical charge.
2. How does a triboelectric generator work?
A triboelectric generator works by utilizing the triboelectric effect. When two materials with different electronegativities are brought into contact and then separated, one material gains electrons and becomes negatively charged, while the other loses electrons and becomes positively charged. This charge separation creates an electrical potential difference, which can be used to generate electricity.
3. What are the applications of triboelectric generators?
Triboelectric generators have a wide range of potential applications, including energy harvesting in wearable devices, self-powered sensors, and environmental monitoring systems. They can also be used in biomedicine, such as powering implantable medical devices, and in renewable energy sources, such as wind and water turbines.
4. What are the advantages of triboelectric generators?
One of the main advantages of triboelectric generators is their ability to generate electricity from various types of mechanical motion, including bending, twisting, and sliding. They are also lightweight, low cost, and can be easily integrated into different devices. Additionally, triboelectric generators have a high power density and can produce electricity even in low wind or water flow conditions.
5. What are the challenges facing triboelectric generators?
Some of the challenges facing triboelectric generators include the need for further research and development to improve their efficiency and stability, as well as their compatibility with different materials and environments. They also face competition from other energy harvesting technologies, such as piezoelectric and thermoelectric generators.
  • Electrical Engineering
  • Quantum Interpretations and Foundations
19K
  • Astronomy and Astrophysics
9K
  • General Engineering
9K
