Trick complicated limit
  • Thread starter namu
How do I find the following limit?
[itex]lim_{x\rightarrow 0} (\frac{\tan x}{x})^{1/x^2}[/itex]
L'Hospital's rule gets really messy, and I cannot find a suitable
choice of functions to apply the squeeze theorem. Does anyone
have any suggestions? Thank you.
Answers and Replies
dextercioby
Insights Author
13,070
637
Compute the natural logarithm of the limit with the help of l'Ho^pital's rule.
Thank you. That makes life so much easier. I forgot about that little trick.
I got the answer.
6,734
It shouldn't, because L'Hopital's Rule doesn't apply here. It applies to quotients of functions -- f(x)/g(x) -- where both functions are approaching zero or both are approaching infinity.
And you can't simply use L'Hopital's Rule on the part being raised to the power, because the limit variable occurs in the exponent.
That's true, so we have
[itex]
\stackrel{lim}{x \to 0} \frac{\tan x}{x}^{1/x^2}= e^{\stackrel{lim}{x \to 0}\frac{ln \frac{\tan x}{x}}{\frac{1}{x^2} }}
[/itex]
Now,
[itex]
\stackrel{lim}{x \to 0} \frac{\tan x}{x}=1
[/itex]
hence,
[itex]
ln 1=0
[/itex]
and
[itex]
\stackrel{lim}{x \to 0} \frac{1}{x^2}=0
[/itex]
Therefore we can use l'Hospital's Rule here with [itex]f=ln \frac{\tan x}{x} [/itex] and [itex]g=1/x^2 [/itex]
6,734
What you wrote is pretty hard to read and comprehend, so I can't tell if you're on the right track, plus some of what you wrote is just wrong.
[tex]\lim_{x \to 0}\frac{1}{x^2} \neq 0![/tex]
When you work this problem, don't include the limit until you're ready to take the limit.
Write y = (tan(x)/x)^(1/x^2)
Now take ln of both sides, and you'll have a quotient.
Take the limit of ln y and of what you have on the right, and use L'Hopital's Rule on that. This is what dextercioby was saying.
Keep in mind that the limit you'll get is the limit of the ln of something, so you'll need to adjust for that.
LaTeX tips
1) For complicated fractions, use [ tex ] tags instead of [ itex ] tags.
2) For limits, don't use \stackrel -- use \lim, like this:
[ tex ]\lim_{x \to {\infty}\frac{f(x)}{g(x)}[ /tex ]
Thank you very much for the LaTeX tips. Sorry, I'm new to PF and was not aware that tex can be used. Oh I see, the i in itex stands for inline instead of the usual $. That explains a lot. Also, I made a mistake when quickly typing this up, so yes, there is a mistake.
The correct response should be
[tex]\lim_{x \to {\infty}} \left ( \frac{\tan x}{x} \right ) ^{1/x^2}=e^{\lim_{x \to {\infty}} \frac{1}{x^2} ln \frac{\tan x}{x} } [/tex]
So,
[tex] f(x)=ln \frac{\tan x}{x} [/tex]
[tex] g(x)=x^2 [/tex]
Now [itex] f(x) \to 0 [/itex] and [itex] g(x) \to 0 [/itex]
Dick
26,260
619
So,
Ok, so now you have a 0/0 limit. What do you get for the limit using l'Hopital? This whole thing is probably worked out easier using taylor series, if you know that approach.
Related Threads on Trick complicated limit
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
