Calculate Volume of Solid with Hole: Ball of Radius 12 and Hole of Radius 7
  • Thread starter ratroll01
  • Tags
    Volume
In summary, the problem asks for the volume of a solid resulting from a ball with a radius of 12 and a hole of radius 7 drilled through its center. The solution involves finding the volume of a sphere with a radius of 12 and subtracting the volume of a cylinder with a radius of 7 and height 12. Alternatively, the exact answer can be obtained by using the equation for a circle and the indefinite integral formula for volume, with the correct limits chosen. The radius of the hole can be found by considering the case where the semi-circle is touching the Y axis.
ratroll01
A ball of radius 12 has a round hole of radius 7 drilled through its center. Find the volume of the resulting solid.
I tried to do it as though it is a ball with a radius of 12 missing a ball with a radius of 7 from its center and got an answer around 2900. But it is actually a ball with a radius of 12 with a hole of radius of center, if that makes sense. Like you could see through the ball. I have no idea how to approach this..
Do you need an exact answer? You could approximate it very easily by using the volume of a sphere with 12 as it's radius and subtract the volume of a cylinder with radius 7 and height 12?
edit: The exact answer is obtained (one way) by using the equation for a circle (x*x + y*y = r*r, solve for the necessary variable) and the indefinite integral formula for finding volume (remember to choose the right limits).
First consider the case where the semi-circle is touching the Y axis. What is the radius of the hole generated by the volume created by revolution about the y axis?
picture:
http://img132.imageshack.us/img132/1650/helpbn7.jpg [Broken]
What is a "Trickey volume question"?
A "Trickey volume question" is a type of question that involves finding the volume of a complex or irregularly shaped object or space. These questions often require creative thinking and use of mathematical formulas.
Why are "Trickey volume questions" important to study?
Studying "Trickey volume questions" can help develop problem-solving skills and critical thinking abilities. It also has practical applications in fields such as engineering, architecture, and physics.
What are some strategies for solving "Trickey volume questions"?
Some strategies for solving "Trickey volume questions" include breaking the object or space into smaller, more manageable shapes, using formulas for specific shapes, and visualizing the object in 3D to better understand its dimensions.
Are there any common mistakes to avoid when solving "Trickey volume questions"?
One common mistake when solving "Trickey volume questions" is forgetting to convert units, such as from centimeters to meters. It is also important to double-check calculations and be careful with decimal points.
What are some real-world examples of "Trickey volume questions"?
Real-world examples of "Trickey volume questions" can include finding the volume of an irregularly shaped swimming pool, calculating the volume of a complex piece of machinery, or determining the volume of an underground cave system.
