Homework Help: Tricky Definite Integral
  1. Mar 9, 2013 #1
    1. The problem, the whole problem, and nothing but the problem
    [tex] \int_0^\pi \frac{x \cdot sin(x)}{1+cos^2(x)} \, dx [/tex]
    2. Relevant equations
    Integration by parts
    trig substitution
    3. The attempt at a solution
    My first idea was to break up the integral by letting [itex]u=x[/itex] and [itex]dv=sin(x)/(1+cos^2 x)[/itex]. I will omit the work, but it got me here:
    [tex] \int_0^\pi \frac{x \cdot sin(x)}{1+cos^2(x)} \, dx = (x \cdot tan^{-1} (cos(x)) \big|_0^\pi - \int_0^\pi tan^{-1}(cos(x)) \, dx [/tex]
    I am fairly sure that I arrived at the second integral correctly. Is it integrateable, if that's a word?
  3. Mar 9, 2013 #2
    Dick
    [itex] works for inline. For the integral, it is a trick. Try substituting u=pi-x. Finding an indefinite integral is really pretty hopeless.
  4. Mar 9, 2013 #3
    [tex]- \int_0^\pi tan^{-1} cos(x) \, dx [/tex]
    [tex] u= \pi-x, du=- dx [/tex]
    [tex] \int_\pi^0 tan^{-1} cos(\pi-u) \, du [/tex]
    [tex] - \int_0^\pi tan^{-1}(cos(\pi)cos(u) + sin(\pi)sin(u)) \, du [/tex]
    [tex] - \int_0^\pi tan^{-1}(-cos(u)) \, du [/tex]
    [tex] \int_0^\pi tan^{-1}cos(u) \, du [/tex]
    Hmm... does that mean that since the top equation is equal to the bottom, and they are negatives, the integral must be 0?
  5. Mar 9, 2013 #4
    Dick
    I meant you to use that substitution in the original integral. You should get the original integral back with a different sign plus something you can integrate. Equate it to the original integral.
  6. Mar 9, 2013 #5
    [tex] \int_0^\pi \frac{x \cdot sin(x)}{1+cos^2x} \, dx [/tex]
    [tex] u=\pi-x, du=-1 [/tex]
    [tex] - \int_\pi^0 \frac{(\pi-u)(sin(\pi-u))}{1+cos^2(\pi-u)} \, du [/tex]
    [tex] \int_0^\pi \frac{(\pi-u)(-sin(u))}{1+ cos^2(\pi-u)} \, du[/tex]
    [tex] -\int_0^\pi \frac{sin(u)(\pi-u)}{1+ cos^2(\pi-u)} \, du [/tex]
    [tex] -\int_0^\pi \frac{sin(u)(\pi-u)}{1+ (-cos(u))^2} \, du [/tex]
    [tex] -\int_0^\pi \frac{sin(u)(\pi-u)}{1+ cos^2u} \, du [/tex]
    [tex] -\pi \int_0^\pi \frac{sin(u)}{1+ cos^2u} \, du + \int_0^\pi \frac{u \cdot sin(u)}{1+ cos^2u} [/tex]
    [tex] v=cos(u), dv=-sin(u) \, du[/tex]
    [tex] \pi \int_1^{-1} \frac{dv}{1+v^2} + \int_0^\pi \frac{u \cdot sin(u)}{1+ cos^2u} [/tex]
    Going back to the beginning:
    [tex] \int_0^\pi \frac{x \cdot sin(x)}{1+cos^2x} \, dx = -\pi \int_{-1}^1 \frac{dv}{1+v^2} + \int_0^\pi \frac{u \cdot sin(u)}{1+ cos^2u} [/tex]
    [tex]0=\int_{-1}^1 \frac{dv}{1+v^2} [/tex]
    Am I on the right track?
  7. Mar 9, 2013 #6
    Dick
    First fix an error. sin(pi-u)=sin(u). Then break it into two integrals.
  8. Mar 9, 2013 #7
    [tex] \int_0^\pi \frac{(\pi-u)(sin(u))}{1+ cos^2(\pi-u)} \, du[/tex]
    [tex] \int_0^\pi \frac{sin(u)(\pi-u)}{1+ cos^2(\pi-u)} \, du [/tex]
    [tex] \int_0^\pi \frac{sin(u)(\pi-u)}{1+ (-cos(u))^2} \, du [/tex]
    [tex] \int_0^\pi \frac{sin(u)(\pi-u)}{1+ cos^2u} \, du [/tex]
    [tex] \pi \int_0^\pi \frac{sin(u)}{1+ cos^2u} \, du - \int_0^\pi \frac{u \cdot sin(u)}{1+ cos^2u} [/tex]
    [tex] \pi \int_1^{-1} \frac{dv}{1+v^2} - \int_0^\pi \frac{u \cdot sin(u)}{1+ cos^2u} \, du [/tex]
    Is the following OK:
    [tex] I = \int_0^\pi \frac{x \cdot sin(x)}{1+cos^2x} \, dx = \pi \int_{-1}^1 \frac{dv}{1+v^2} - \int_0^\pi \frac{u \cdot sin(u)}{1+ cos^2u} [/tex]
    [tex]2I = \pi \int_{-1}^1 \frac{dv}{1+v^2} [/tex]
    If so, how can I evaluate this integral?
  9. Mar 9, 2013 #8
    Dick
    You know, having to constantly go back and check whether you have reedited a past post really sucks. Use preview to see whether you have what you want, then just LEAVE IT. If you change your mind, just post the correction. Don't go back and change the past. And yes, your result is fine.
  10. Mar 9, 2013 #9
    Sorry
  11. Mar 9, 2013 #10
    Dick
    S'ok. Just advice for the future. But you got the right answer.
  12. Mar 9, 2013 #11
    So the answer is just 0?
  13. Mar 9, 2013 #12
    Dick
    It's an arctan, isn't it? Why do you think it's zero?
  14. Mar 9, 2013 #13
    Dick
    Now I forgot to quote the integral. Doesn't look like zero to me.
  15. Mar 9, 2013 #14
    Oh, right. I'm pretty tired right now. Just did out the trig substitution and verified that it's 0. How did you know to make the substitution u=pi-x?
  16. Mar 9, 2013 #15
    [itex] 1/(1+v^2)[/itex] is also an even function which is probably enough to show that the answer is 0, considering that the upper limit is equal to the lower limit
  17. Mar 9, 2013 #16
    Dick
    Tired, ok. But it's NOT zero. Check it in the morning if that works better. I guessed to do the substitution because I've seen problems like this before. Just experience.
  18. Mar 9, 2013 #17
    Dick
    Wrong. Get some sleep if you need to.
  19. Mar 9, 2013 #18
    [tex] \int_{-1}^1 \frac{dv}{v^2+1} [/tex]
    [tex] v= tan\theta, dv=sec^2\theta d\theta [/tex]
    [tex] \int_{-\pi/4}^{\pi/4} \frac{sec^2 \theta}{sec^2 \theta} d\theta [/tex]
    [tex] \int_{-\pi/4}^{\pi/4} \theta d\theta [/tex]
    [tex] \frac{\theta^2}{2} \big|_{-\pi/4}^{\pi/4} [/tex]
    [tex] (\pi/4)^2/2 - (-\pi/4)^2/2 [/tex]
    Alright, I see that I'm wrong by looking at the graph. What's the problem here?
  20. Mar 9, 2013 #19
    Dick
    Now you are making me sleepy. sec(θ)^2/sec(θ)^2 isn't θ. It's 1.
  21. Mar 9, 2013 #20
    [tex] \theta \big|_{-\pi/4}^{\pi/4} = \pi/2 [/tex]
    [tex] 2I= \pi/2[/tex]
    [tex] I = \pi/4 [/tex]
    Were there any arithmetic errors in there? haha
  22. Mar 9, 2013 #21
    Dick
    Sadly, yes. You dropped the factor of pi you had correct in post 7. You would do it easily with the hint I gave you if you were less tired.
  23. Mar 9, 2013 #22
    Alright, so [itex] I = \pi^2/4 [/itex]. Thank you very much for the help, now I'm going to get some beauty sleep
  24. Mar 9, 2013 #23
    Dick
    Very welcome, and good idea!
Have something to add?
Draft saved Draft deleted
