Tricky integral
  • Thread starter jbowers9
jbowers9
89
I recently tried to do the following integral:
an = ∫√(2/a) sin(n∏x/a) cosh(x) dx
x=0 to x=a
an = ∫√(2/a) sin(βx) cosh(x) dx
β = n∏/a
sin(βx) = ½i(eiβx – e-iβx)
cosh(x) = ½(ex + e-x)
an = ¼ i √(2/a)∫ (eiβx – e-iβx) (ex + e-x)
after all is said and done, I get;
an = √(2/a)[(a2sin(n∏)sinh(a) – acos(n∏)cosh(a) + n∏a)/(n22 + a2)]
The text, “Quantum Mechanics Demystified”, however, gets;
an = √(2/a)[a(n∏cos(n∏)cosh(a) + sin(n∏)sinh(a))/( n22 + a2)]
Which is correct? And why?
Answers and Replies
8,284
x=0 to x=a
β = n∏/a
cosh(x) = ½(ex – e-x)
an = ¼ i √(2/a)∫ (eiβx – e-iβx) (ex – e-x)
Your approach is the one I would take, so here is what I would do:
Check your work to see if you can find any errors.
Take the derivative of your result. Do you get the integrand?
Take the derivative of the book's result. Do you get the integrand?
If the answers to both questions are yes, the two antiderivatives are equal or differ by a constant.
If one answer is yes and the other is no, the result from the "yes" answer is almost surely correct and the other is incorrect. It's even possible that the answer in the book is wrong.
gabbagabbahey
x=0 to x=a
I get;
If you've written the Integral correctly, then your solution is closer than the one from the text; it should have an aSin(....) term instead of an a2Sin(...)....Of course, if n is an integer then the sin (n*pi) term is zero and cos(n*pi)=(-1)n.
So, are you sure you are evaluating the correct integral?
gabbagabbahey
Usually these are good strategies for checking a solution, but in this case the integral is a definite integral, so differentiating the textbook's solution will naturally give zero.
jbowers9
89
I made an error transcribing the above and corrected the cosh(x) term. I've redone it 3 times and still get my results.
Suggested for: Tricky integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
