Tricky integral
  • Thread starter capicue
I need a hint. Wolfram alpha says it equals pi/2, but I don't know how to get that.
\int_{-\infty}^{\infty} \frac{\sin^4(x)}{x^2}\, dx
Answers and Replies
Did you make a typo?
I don't think so. Here's the Wolfram alpha solution.
Are you familiar with contour integration?
Yes. I thought about trying something like that, but the usual substitution z = e^{ix} to write the sin part as an exponentials doesn't work with the x^2 on the bottom.
What were you thinking about with the contour integration?
My other thought was to try to relate it back to \int sin(x)/x which is something I can do.
I haven't worked it out but if you write out the sin^4 and then use contour integration it will probably work:
[tex] \sin^4\theta = \frac{3 - 4 \cos 2\theta + \cos 4\theta}{8}\ [/tex]
You're right, that would probably work. I'll give it a go. Thanks for your help!
Alternatively, I figured out how to reduce it:
[tex]
\int_{-\infty}^{\infty} \frac{\sin^4{x}}{x^2}\, dx = \int_{-\infty}^{\infty} \frac{4 \sin^3{x} \cos{x}}{x}\, dx
[/tex]
(IBP)
[tex]
= \int_{-\infty}^{\infty} \frac{\sin{2x}(1 - \cos{2x})}{x}\, dx
[/tex]
(trig identities)
[tex]
= \int_{-\infty}^{\infty} \frac{\sin{2x}}{x}\, dx - \int_{-\infty}^{\infty} \frac{\sin{4x}}{2x}\, dx
[/tex]
[tex]
= \int_{-\infty}^{\infty} \frac{\sin{x}}{x}\, dx - \frac{1}{2} \int_{-\infty}^{\infty} \frac{\sin{x}}{x}\, dx
[/tex]
(change of variables)
[tex]
= \pi - \frac{\pi}{2}
[/tex]
(sinc integral)
Yes, well found!
Related Threads on Tricky integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
