Solving cot x = (3)^(1/4): pi/6 & 5pi/6
  • Thread starter Aaron H.
In summary, There are two solutions to the equation cot x = (3)^(1/4): pi/6 and 5pi/6. To solve this equation without a calculator, you can use the trigonometric identity cot x = 1/tan x and take the inverse tangent and inverse cotangent of (3)^(1/4). The reason for two solutions is because cotangent is a periodic function. You can also use the Pythagorean identity sin^2 x + cos^2 x = 1 to solve for sin x and cos x and then use inverse trigonometric functions to find x. To check if your solutions are correct, you can use a calculator or graphing calculator.
Aaron H.
Solve, finding all solutions in [0, 2pi)
sqrt (cot x) = (3)^(1/4)
[sqrt (cot x) = (3)^(1/4)]^4 =
sqrt [cot^2 x = 3] =
cot x = +/- sqrt (3)
x = pi/6, 5pi/6, 7pi/6, 11pi/6
the answer choices to this problem only have two angles each, so two of the angles I derived aren't necessary
Since the original problem has (cot x), the solution can't include the values corresponding to cot x = -√3.
1. What is the solution to cot x = (3)^(1/4)?
There are two solutions to this equation: pi/6 and 5pi/6.
2. How can I solve cot x = (3)^(1/4) without a calculator?
To solve this equation without a calculator, you can use the trigonometric identity cot x = 1/tan x. Then, you can solve for tan x by taking the inverse tangent of both sides. Finally, solve for x by taking the inverse cotangent of (3)^(1/4).
3. Why are there two solutions to this equation?
Since cotangent is a periodic function, it repeats itself every pi radians. Therefore, there are multiple angles that satisfy the equation cot x = (3)^(1/4).
4. Can I use a different method to solve this equation?
Yes, you can also use the Pythagorean identity sin^2 x + cos^2 x = 1 to solve for sin x and cos x. Then, you can use the inverse sine and cosine functions to find the values of x.
5. How can I check if my solutions are correct?
You can use a calculator to check if your solutions are correct. Simply plug in the values of pi/6 and 5pi/6 into the original equation cot x = (3)^(1/4) and see if they give you the same value on both sides of the equation. Alternatively, you can also use a graphing calculator to graph both sides of the equation and see where they intersect.
