• Support PF! Buy your school textbooks, materials and every day products Here!
Trig identities proof
I'm solving a pretty descent trig identity question, but I'm stuck. I'm not going to type out the original question, but here the section that I'm stuck on: sin^4x + cos^4x and here is what I have to prove: 1-2sin^2xcos^2x
I know that I'm really close, I just can't get this section. Any help is much appreciated.
Answers and Replies
1,750
Show your work and you'll get a lot of help.
1,750
To be honest, there is just too much to type out.
To be honest, I don't care. Wait for someone else :)
... I would like your help, I just don't know what to type out. Basically, I rearranged the equation using sine and cosine and I ended up with sin^4x + cos^4x/sinxcosx.
1,750
What are you trying to do? Make the Left equal the Right?
From the first line my next line is:
sin^3x/cos^3x / 1/cos^2x + cos^3x/sin^3x / 1/sin^2x
then, sin^3x/cos^3x x cos^3x / 1/cos^2x x cos^3x + cos^3x/sin^3x x sin^3x / 1/sin^2x x sin^3x
then, sin^4x + cos^4x / sinx x cosx
so, as you can see, I'm stuck. You can't simplify the sum of two even powers, so I have clue what to do next.
Gib Z
3,344
We can simplify [itex]\sin^4 x + \cos^4 x[/itex] quite well actually, stick with what you're trying =]
We CAN simplify any polynomial expression with real coefficients into linear and quadratic terms, or if you don't mind complex coefficients, all linear terms. This is most easily been, and actually directly stated, by the Fundamental Theorem of Algebra, but also can be cleverly seen with a nice application of the conjugate root theorem =] It doesn't matter if you don't understand most of this by the way.
Perhaps you should try completing the square =] ?
454
the only other thing you need is [tex] sin^2x + cos^2x = 1 [/tex]
tiny-tim
25,789
249
Hi snooooooooooz! :zzz:
Hint: you know what sin^2x + cos^2x is, don't you?
Well, how can you use that to help with sin^4x + cos^4x? :smile:
EDIT: Actually, I don't see how you can use completing the square to factor sin^4x + cos^4x.
tiny-tim
25,789
249
snooooooooooz, stop trying to factorise it! :frown:
The object is to simplify it. :smile:
Use the hint that kamerling and I gave you:
sin^2x + cos^2x = 1​
ok so if I take sin^2x + cos^2x out of sin^4+cos^4x that means I'm left with sin^2x + cos^2x. Since sin^2x + cos^2x = 1 and cos^2x = 1-sin^2x there is NO cos^2x at the end to multiply by. There is no way I can see how sin^4x + cos^4x can equal 1-2sin^2x cos^2x
454
try to write both expressions using just [tex]sin^2x[/tex]
tiny-tim
25,789
249
… BIG hint …
Hint: what is (sin^2x + cos^2x)^2 ? :smile:
tiny-tim
25,789
249
No!!
Your next line is: (sin^2x + cos^2x) x (sin^2x + cos^2x)
No!!
But if you foil that out you get sin^4x + sin^2xcos^2x + cos^2xsin^2x + cos^4x.
So I got [tex] sin^4x +2sin^2xcos^2x + cos^4x [/tex]. How would drop the [tex] sin^4x [/tex] and [tex] cos^4x [/tex] to make that into a 1-?
tiny-tim
25,789
249
(what's "foil"?)
Yes! Or, slightly simpler: sin^4x + cos^4x + 2sin^2xcos^2x.
Now your next line is:
So sin^4x + cos^4x + 2sin^2xcos^2x = … ? :smile:
(what's "foil"?)
Sorry, "foil" is distributive property. I'm just going to assume that sin^4x + cos^4x = 1- but how?
tiny-tim
25,789
249
Because 1 = (sin^2x + cos^2x)^2 = sin^4x + cos^4x + 2sin^2xcos^2x;
so sin^4x + cos^4x = 1 - 2sin^2xcos^2x. :smile:
So your next line is … ?
but where did the negative come from?
tiny-tim
25,789
249
ah! algebra difficulties!
hmm … if 1 = A + B + C,
:smile: then A + B = 1 - C. :smile:
Yes? No? You have to be able to do these!
If you just let: sin2x = a
and: cos2x = b
then,
a2 = sin4
and
b2 = cos4
thus,
a2 + b2 + 2ab = (a + b)2
or, a2 + b2 + 2ab - 2ab = (a + b)2 - 2ab
or, a2 + b2 = (a + b)2 - 2ab
then what?
Related Threads for: Trig identities proof
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
