Proving Trig Identities: Solving sin^4x + cos^4x = 1-2sin^2xcos^2x
In summary, the conversation is about solving a trigonometry identity involving sin^4x + cos^4x and proving that it is equal to 1-2sin^2xcos^2x. The person solving the question is stuck and looking for help. They are advised to use the hint sin^2x + cos^2x = 1 to simplify the expression. They continue to work through the problem and eventually reach the solution that sin^4x + cos^4x = 1-2sin^2xcos^2x, using the distributive property and simplifying the equation.
snooooooooooz
I'm solving a pretty descent trig identity question, but I'm stuck. I'm not going to type out the original question, but here the section that I'm stuck on: sin^4x + cos^4x and here is what I have to prove: 1-2sin^2xcos^2x
I know that I'm really close, I just can't get this section. Any help is much appreciated.
Show your work and you'll get a lot of help.
snooooooooooz said:
To be honest, there is just too much to type out.
To be honest, I don't care. Wait for someone else :)
... I would like your help, I just don't know what to type out. Basically, I rearranged the equation using sine and cosine and I ended up with sin^4x + cos^4x/sinxcosx.
What are you trying to do? Make the Left equal the Right?
Yes, you're proving that one side equals the other side.
From the first line my next line is:
sin^3x/cos^3x / 1/cos^2x + cos^3x/sin^3x / 1/sin^2x
then, sin^3x/cos^3x x cos^3x / 1/cos^2x x cos^3x + cos^3x/sin^3x x sin^3x / 1/sin^2x x sin^3x
then, sin^4x + cos^4x / sinx x cosx
so, as you can see, I'm stuck. You can't simplify the sum of two even powers, so I have clue what to do next.
We can simplify [itex]\sin^4 x + \cos^4 x[/itex] quite well actually, stick with what you're trying =]
We CAN simplify any polynomial expression with real coefficients into linear and quadratic terms, or if you don't mind complex coefficients, all linear terms. This is most easily been, and actually directly stated, by the Fundamental Theorem of Algebra, but also can be cleverly seen with a nice application of the conjugate root theorem =] It doesn't matter if you don't understand most of this by the way.
Perhaps you should try completing the square =] ?
the only other thing you need is [tex] sin^2x + cos^2x = 1 [/tex]
Hi snooooooooooz! :zzz:
Hint: you know what sin^2x + cos^2x is, don't you?
Well, how can you use that to help with sin^4x + cos^4x? :smile:
EDIT: Actually, I don't see how you can use completing the square to factor sin^4x + cos^4x.
snooooooooooz, stop trying to factorise it! :frown:
The object is to simplify it. :smile:
Use the hint that kamerling and I gave you:
sin^2x + cos^2x = 1​
ok so if I take sin^2x + cos^2x out of sin^4+cos^4x that means I'm left with sin^2x + cos^2x. Since sin^2x + cos^2x = 1 and cos^2x = 1-sin^2x there is NO cos^2x at the end to multiply by. There is no way I can see how sin^4x + cos^4x can equal 1-2sin^2x cos^2x
try to write both expressions using just [tex]sin^2x[/tex]
… BIG hint …
Hint: what is (sin^2x + cos^2x)^2 ? :smile:
ok.. so my next line is: [tex]1 [/tex] x [tex]sin^2x +cos^2x[/tex]?
No!
Your next line is: (sin^2x + cos^2x) x (sin^2x + cos^2x)
tiny-tim said:
No!
But if you foil that out you get sin^4x + sin^2xcos^2x + cos^2xsin^2x + cos^4x.
So I got [tex] sin^4x +2sin^2xcos^2x + cos^4x [/tex]. How would drop the [tex] sin^4x [/tex] and [tex] cos^4x [/tex] to make that into a 1-?
(what's "foil"?)
Yes! Or, slightly simpler: sin^4x + cos^4x + 2sin^2xcos^2x.
Now your next line is:
So sin^4x + cos^4x + 2sin^2xcos^2x = … ? :smile:
tiny-tim said:
(what's "foil"?)
Sorry, "foil" is distributive property. I'm just going to assume that sin^4x + cos^4x = 1- but how?
Because 1 = (sin^2x + cos^2x)^2 = sin^4x + cos^4x + 2sin^2xcos^2x;
so sin^4x + cos^4x = 1 - 2sin^2xcos^2x. :smile:
So your next line is … ?
but where did the negative come from?
ah! algebra difficulties!
hmm … if 1 = A + B + C,
:smile: then A + B = 1 - C. :smile:
Yes? No? You have to be able to do these!
If you just let: sin2x = a
and: cos2x = b
then,
a2 = sin4
and
b2 = cos4
thus,
a2 + b2 + 2ab = (a + b)2
or, a2 + b2 + 2ab - 2ab = (a + b)2 - 2ab
or, a2 + b2 = (a + b)2 - 2ab
then what?
1. What is a trigonometric identity?
A trigonometric identity is a mathematical equation that is true for all values of the variable within a specific domain. It is used to simplify or solve trigonometric equations and can involve one or more trigonometric functions.
2. How do I prove a trigonometric identity?
To prove a trigonometric identity, you need to use algebraic manipulations and trigonometric identities, such as Pythagorean identities, double angle identities, and sum and difference identities, to transform one side of the equation into the other.
3. What is the first step in proving the identity sin^4x + cos^4x = 1-2sin^2xcos^2x?
The first step is to rewrite the left side of the equation using the Pythagorean identity sin^2x + cos^2x = 1.
4. What is the next step after rewriting the left side of the equation?
The next step is to use the double angle identity for cosine, cos^2x = (1+cos2x)/2, to expand the left side of the equation.
5. How do I complete the proof for sin^4x + cos^4x = 1-2sin^2xcos^2x?
After expanding the left side of the equation, you can use the Pythagorean identity sin^2x + cos^2x = 1 and the double angle identity for sine, sin^2x = (1-cos2x)/2, to simplify the equation. This will result in the right side of the equation, proving the trigonometric identity.
  • Precalculus Mathematics Homework Help
