Trig Identities
  • Thread starter preet
Hi... I need help solving this problem. I don't know what to do...
Proove that
[tex]\frac{cos^2\theta - sin^2\theta}{cos^2\theta+sin\theta cos\theta} = 1 - tan\theta[/tex]
I tried to cross out cos^2 on the top with the one at the bottom... also tried messing around with the values (cos^2x = 1 - sin^2x) etc... but nothing is working. I'm kind of lost and would appreciate any help... Thanks
Answers and Replies
First if you are given [tex]\frac{cos^2\theta - sin^2\theta}{cos^2\theta+sin\theta cos\theta} = 1 - tan\theta[/tex] factor the numerator (its a difference of two perfect squares). Then factor the denominator (can you see a common term?) Cancel like terms. Divide through and you will get your result.
Hint: [tex] a^2 - b^2 = (a-b)(a+b) [/tex]
Cross out with [tex]cos^2(x)[/tex] also works.
[tex]\frac{cos^2(x)-sin^2(x)}{cos^2(x)}[/tex]
[tex]\frac{cos^2(x)+sin(x)cox(x)}{cos^2(x)}[/tex]
When you solve these, the answer comes out very nicely
maybe it's because it's only been a little over a week from the xmas break, but even after factoring, I don't know the next step... how can i cancel out stuff still in the brackets? And for crossing it out... I don't really get what happened. What did you cross out exactly, and why is the fraction flipped?
factored...
[tex]\frac{(cos\theta + sin\theta) (cos\theta - sin\theta)}{(cos\theta+sin\theta)(cos\theta)}[/tex]
In the denominator, inside the brackets you get [tex](cos\theta+sin\theta)[/tex] because before factoring you had [tex]cos^2\theta[/tex]. Now do some cancelling out and you will get the answer.
yah, i just caught my mistake ... but im still not getting 1-tan theta...
I end up with cos theta - sin theta over cos theta after cancelling...
ok so you see [tex]\frac{(cos\theta + sin\theta) (cos\theta - sin\theta)}{(cos\theta+sin\theta)(cos\theta)}[/tex] [tex](cos\theta+sin\theta)[/tex] both in the numerator and denominator. So cancel that out and you are left with:
[tex]\frac{(cos\theta - sin\theta)}{(cos\theta)}[/tex]
Simplify this and you get the answer
[tex]\frac{cos\theta-sin\theta}{cos\theta}=\frac{cos\theta}{cos\theta}-\frac{sin\theta}{cos\theta}[/tex]
Curious3141
2,850
87
What is the definition of [itex]\tan \theta[/itex] in terms of [itex]\sin \theta[/itex] and [itex]\cos \theta[/itex] ?
mmmannnn.... I think I need another vacation. Thanks for the help =)
Related Threads on Trig Identities
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
