Trig identity and equations
In summary: For function 3, the domain is restricted to (-\infty . +\infty) however the range for function 3 is limited and x can only be a specific value. Therefore, the solution for R is:\boxed{x = \cos^{-1} \frac{2}{5}}
needhelp123
how can i do this trig identity
ln|sec(theta) + tan(theta| + ln|sec(theta) + tan(theta)| = 0
and this trig equation
4sin(squared)x + 2cos(squared)x = 3
and cos2(theta) + 3 = 5cos(theta)
any help will be appreciated
Mathematics news on Phys.org
Rewrite the first.It doesn't make any sense.
For the second,use [itex] \cos^{2}x=1-\sin^{2}x [/itex] for transform it into a quadratic in "sin x".
For the third,use [itex] \cos 2x=2\cos^{2}x-1 [/tex] to transform it into a quadratic in "cos x".
Daniel.
ln|sec(theta) + tan(theta)| + ln|sec(theta) - tan(theta)| = 0
| (line) is absolute value
There's no big deal
[tex] \ln\left|\sec\theta+\tan\theta\right|+\ln\left|\sec\theta-\tan\theta\right|=\ln|\sec^{2}\theta-\tan^{2}\theta|=\ln 1 =0 [/tex]
Q.e.d.
Daniel.
Every one of those equations is nonsense. Sure you need help, you need help to transcribe your questions accurately. You are doomed to failure in any problem if you can't even write the problem description properly.
BTW. Congrats to dextercioby for figuring out what you actually meant to write in at least one of those problems.
Practical Practice...
Trig identity confirmed:
[tex]\boxed{\ln\left|\sec\theta+\tan\theta\right|+\ln\left|\sec\theta-\tan\theta\right|=\ln|\sec^{2}\theta-\tan^{2}\theta|=\ln 1 =0} [/tex]
[tex] 4 \sin^2 x + 2 \cos^2 x = 3 [/tex]
[tex] \cos^2 x = 1 - \sin^2 x [/tex] - identity
[tex] 4 \sin^2 x + 2(1 - \sin^2 x) - 3 = 0 [/tex]
[tex] 4 \sin^2 x + 2 - 2 \sin^2 x - 3 = 0 [/tex]
[tex] 4 \sin^2 x - 2 \sin^2 x - 1 = 0 [/tex]
[tex] 2 \sin^2 x - 1 = 0 [/tex]
[tex] \sin^2 x = \frac{1}{2} [/tex]
[tex] \boxed{\sin x = \pm \frac{\sqrt{2}}{2}} [/tex]
:biggrin:
[tex] \cos 2x + 3 = 5 \cos x [/tex]
[tex] \cos 2x - 5 \cos x + 3 = 0 [/tex]
[tex] \cos 2x = 2 \cos^2 x - 1 [/itex] - identity
[tex] (2 \cos^2 x - 1) - 5 \cos x + 3 = 0 [/tex]
[tex] 2 \cos^2 x - 5 \cos x + 2 = 0 [/tex]
[tex] a = 2 \; \; b = -5 \; \; c = 2 [/tex]
[tex] \cos x = \frac{-(-5) \pm \sqrt{(-5)^2 - 4(2)(2)}}{2(2)} [/tex]
[tex] \cos x = \frac{5 \pm \sqrt{9}}{4} [/tex]
[tex] \cos x = \frac{5 \pm 3}{4} [/tex]
[tex] \boxed{\cos x = \frac{1}{2}} [/tex]
[tex] \cos x = 2 \; \; \text{(no solution)} [/tex]
:biggrin:
U have to disregard [itex] \cos x=2 [/itex],okay?
Daniel.
Daniel.
Unless the question asks for complex solutions.
"x" typically depicts real variable...:wink:
If it were "z",it may have considered imaginary solutions,too...
Daniel.
Practice Problems...
It is my opinion that if the original equation states both [itex] \sin x [/itex] and [itex] \cos x [/itex] then both solutions must be located in order to lock on the solution quadrants, if possible.
[tex] \sin^2 x = 1 - \cos^2 x [/tex] - identity
[tex] 4 (1 - \cos^2 x) + 2 \cos^2 x - 3 = 0 [/tex]
[tex] 4 - 4 \cos^2 x + 2 \cos^2 x - 3 = 0 [/tex]
[tex] -2 \cos^2 x + 1 = 0 [/tex]
[tex] \cos^2 x = \frac{1}{2} [/tex]
[tex] \boxed{\cos x = \pm \frac{\sqrt{2}}{2}} [/tex]
[tex] \boxed{\cos x = \pm \frac{\sqrt{2}}{2} \; \; \sin x = \pm \frac{\sqrt{2}}{2}} [/tex]
[tex] \boxed{x = \pm \frac{\pi}{4} \; \; x = \pm \frac{3 \pi}{4}} [/tex] - solution 1
[tex] \boxed{x = \frac{\pi}{4} \; \; x = \frac{3 \pi}{4} \; \; x = \frac{5 \pi}{4} \; \; x = \frac{7 \pi}{4}} [/tex] - solution 2
:uhh:
By locking on the quadrants, a solution for [itex] x [/itex] can be found for 'special angles', without using inverse functions. However, in this equation, solutions exist in all four quadrants.
A physics professor will accept solution 1 or 2 for [itex] x [/itex], however a mathematics professor will only accept solution 2 for [itex] x [/itex].
Nope,as u can see,the initial equations placed no restrictions on the domains of the involved functions.So I'm sorry to dissapoint you,but u have search for solutions in [itex] \mbox{R} [/itex].
Daniel.
orion1
u good ,dont get 2 impressed
orion i still insist u good ,for the second trig question x=60 or 300 which u got right .see ya
Range Rover...
If the range for function 1 is [itex] \left[ 0 . 2 \pi \right] [/itex] then solution 1 and 2 are correct, however if the range for function 1 is [itex](-\infty . +\infty)[/itex] then the number of solutions for [itex]x[/itex] are infinite and the solution for [itex]R[/itex] becomes:
[tex]x = \frac{\pi}{4} + \frac{n \pi}{2} = \frac{\pi}{2} \left( n + \frac{1}{2} \right)[/tex]
[tex]\boxed{ x = \pm \frac{\pi}{2} \left( n + \frac{1}{2} \right)}[/tex]
For function 2, the number of solutions for [itex]x[/itex] are infinite and limited solutions for [itex]x[/itex] becomes:
[tex]x = \cos^{-1} \frac{1}{2}[/tex]
[tex]\boxed{x = \pm \frac{\pi}{3}}[/tex]
[tex]\boxed{x = \frac{\pi}{3} \; \; x = \frac{5 \pi}{3}}[/tex]
For function 2, what is the [itex]x[/itex] solution for [itex]R[/itex]?
1. What are trigonometric identities?
Trigonometric identities are mathematical equations that involve trigonometric functions (such as sine, cosine, and tangent) and are true for all values of the variables in the equation.
2. Why are trigonometric identities important?
Trigonometric identities are important because they allow us to simplify complicated trigonometric expressions and equations, making them easier to solve. They also help us to establish relationships between different trigonometric functions.
3. How can I prove a trigonometric identity?
To prove a trigonometric identity, you can use algebraic manipulation and properties of trigonometric functions to show that one side of the equation can be transformed into the other. You can also use the unit circle and the definitions of trigonometric functions to prove identities.
4. What are some commonly used trigonometric identities?
Some commonly used trigonometric identities include the Pythagorean identities (sin^2x + cos^2x = 1), the double angle identities (sin 2x = 2sinx cosx), and the sum and difference identities (sin(x+y) = sinxcosy + cosxsiny).
5. How can I use trigonometric identities to solve equations?
Trigonometric identities can be used to simplify equations by transforming them into simpler forms. This can make it easier to solve for a specific variable or to identify solutions to the equation. Additionally, identities can be used to verify solutions to an equation.
  • General Math
  • General Math
  • General Math
  • Calculus
