Is my trig identity proof correct?
In summary, the conversation is about the correctness of a proof for the equation \sin^2\theta (1 + sec^2\theta) = sec^2 \theta - cos^2 \theta. The solution given involves manipulating both sides to the same form and simplifying, but another method is proposed to make the solution quicker. The conversation ends with the original poster expressing the need for more practice in trigonometry.
Snoozems
Hi there,
This is my very first post, so I'd like to say thanks for reading and hi basically. :biggrin:
I'm relatively confident my attempt at the proof is correct, but since the method is quite different from other examples I have seen, it kind of makes me nervous. I was hoping someone could verify my answer?
Prove that:
[itex] \sin^2\theta (1 + sec^2\theta) = sec^2 \theta - cos^2 \theta[/itex]
So I try manipulate the right hand side to take exactly the same form as the left. First I rewrite the terms as their 'ordinary' equivalents:
##\dfrac{1}{\cos^2 \theta} - \cos^2 \theta##
##\dfrac{1}{\cos^2 \theta} + \sin^2 \theta - 1##
I then combine the trig terms:
##\dfrac{\sin^2 \theta \cos^2 \theta + 1}{\cos^2 \theta} - 1##
Now I assimilate the constant term of -1:
##\dfrac{\sin^2 \theta \cos^2 \theta - \cos^2\theta + 1}{\cos^2 \theta}##
I now use the fact that ##-\cos^2 \theta + 1 = \sin^2 \theta##:
##\dfrac{\sin^2 \theta \cos^2 \theta + \sin^2 \theta}{\cos^2 \theta}##
I remove the common factor of ##\sin^2 \theta## from the numerator:
##\dfrac{\sin^2 \theta( \cos^2 \theta + 1)}{\cos^2 \theta}##
Next I split the fraction into its constituent products:
##\sin^2 \theta \left(\dfrac{\cos^2 \theta + 1}{\cos^2 \theta} \right)##
Simplifying:
##\sin^2 \theta \left(1 + \dfrac{1}{\cos^2 \theta} \right) \equiv \sin^2\theta (1 + sec^2\theta)##
Have I gone wrong anywhere at all or does this work just fine? Thanks a lot!
~Snooz
No, you do not. You did not remove anything at all. If you had done so, it would be wrong.
I may be wrong about this.
Works just fine.
I may be wrong about this, too.
Doubtful poster is doubtful.
Snoozems said:
Hi there,
Prove that:
Simplifying:
~Snooz
It looks good.
If i were to rewrite the LHS as ##\sin^2\theta+\tan^2\theta##, do you (a) see how I got that and (b) see how to get to the RHS in two very straightforward steps?
Sometimes with these types of problems, it's "fun" to find alternate ways of doing the problems that are potentially easier. It's a skill that'll come in handy down the road if you continue on to calculus.
Works just fine.
Thanks for replying! Yeah it struck me that when I wrote 'removed' that maybe didn't sound exactly right. What I mean to say is I factored the numerator using that common factor of ##\sin^2 \theta##.
gopher_p said:
It looks good.
Thanks, I'm glad it looks all right. I was conscious when I was doing it this was a very long way round of doing it, and I'm very new to using reciprocal trigonometric functions so it isn't quite free flowing yet. In fact, trigonometry is one area of mathematics I haven't given equal attention, and for no good reason.
Haha! Yes, for (a) you just expanded the bracket, and I see how you arrived at (b):
##\sin^2 \theta + \dfrac{\sin^2 \theta}{\cos^2 \theta}##
Since ##\tan^2 \theta = \sec^2 \theta - 1##:
##\sin^2 \theta + \dfrac{1}{\cos^2 \theta} - 1##
Also ##\sin^2 \theta - 1 = - \cos^2 \theta##, so:
Geez! That was much quicker. I'm going to need to put a good bit more practice in here. Thank you very much guys.
The left hand side contains ##\sin## and ##\sec##, and the right hand size has ##\cos## and ##\sec##.
So just shoot to kill and change the ##\sin## to ##\cos##.
LHS = ##(1 - \cos^2\theta)(1 + \sec^2\theta)## and multiply out :smile:
Likes 1 person
1. What is a trig identity?
A trig identity is an equality that relates different trigonometric functions to each other. These identities are used to simplify trigonometric expressions and solve equations involving trigonometric functions.
2. Why is it important to prove trig identities?
Proving trig identities is important because it helps us understand the relationships between trigonometric functions and allows us to manipulate and solve complex trigonometric equations.
3. How do you prove a trig identity?
There are various methods to prove trigonometric identities, including using algebraic manipulation, using trigonometric identities and properties, and using geometric representations of trigonometric functions.
4. What are some common trigonometric identities?
Some common trigonometric identities include the Pythagorean identities, double-angle identities, half-angle identities, and sum and difference identities.
5. Can you provide an example of proving a trig identity?
One example of proving a trig identity is proving the double-angle identity for cosine: cos(2x) = cos^2(x) - sin^2(x). This can be done using the Pythagorean identity sin^2(x) + cos^2(x) = 1 and the sum identity for cosine: cos(A + B) = cos(A)cos(B) - sin(A)sin(B).
