Trig identity question
  • Thread starter Ed Aboud
Basically I am finishing of a projectile question and I get stuck here:
Trying to find [itex] \theta [/itex]
[tex] \frac{1}{2} (sin2 \theta) tan^2 \theta -tan \theta + \frac{1}{2} sin2 \theta = 0[/tex]
I tryed spliting [itex] tan \theta [/itex] into [itex] \frac{sin \theta}{cos \theta} [/itex] but I don't really get anywhere.
I know it requires using a trig identity but I can't really see a suitable one.
Thanks for the help in advance!!
Answers and Replies
gabbagabbahey
The identities [itex]\sin(2\theta)=2\sin(\theta)\cos(\theta)[/itex] and [itex]\sec^2(\theta)=\tan^2(\theta)+1[/itex] should both be useful.
However, you won't be able to solve your equation for [itex]\theta[/itex] since it turns out your equation is true for all [itex]\theta[/itex]!:eek:
You must have made an error earlier in the problem.
hmm I got sin x =0 so x=0.
[tex] sin \theta cos \theta (tan^2 \theta) - tan \theta + sin \theta cos \theta = 0 [/tex]
[tex] sin \theta cos \theta (sec^2 \theta) - \frac{sin \theta}{cos \theta} = 0 [/tex]
[tex] cos^2 \theta (sec^2 \theta) = 1 [/tex]
[tex] 1 =1 [/tex]
gabbagabbahey
Then you should double check your algebra :wink:
gabbagabbahey
[tex] 1 =1 [/tex]
Like I said; your equation is true for all [itex]\theta[/itex], so you must have made an error earlier in the problem.
First thing I did was find rewrite everything in terms of sin and cos:
[tex] sin(\theta)cos(\theta) \frac{sin^{2}(\theta)}{cos^{2}(\theta)} - \frac{sin(\theta)}{cos(\theta)} + sin(\theta)cos(\theta) = 0 [/tex]
Then I found the common denominator and got:
[tex] \frac{sin^{3}(\theta) - sin(\theta) + sin(\theta)cos^{2}(\theta)}{cos(\theta)} = 0 [/tex]
So now we have to consider 2 cases
1) [tex] cos(\theta) = 0 [/tex]
That case cannot hold because your original expression has tan in it and therefore it is assumed that [tex] cos(\theta) \neq 0 [/tex]
2) [tex] cos(\theta) \neq 0 \Rightarrow sin(\theta)(sin^{2}(\theta) - 1 + cos^{2}(\theta)) = 0 [/tex]
The 2nd case gives you 0 = 0 so it seems like your expression holds true for any x.
try searching you double angle rules for something related to sin2x=2sinxcosx and apply it
lol but if you put zero degree in you do get 0. I have probability done something wrong.
Zero degree? Are you saying if you evaluate it at theta = 0 you get 0 = 0? Did you read the post I made?
gabbagabbahey
Try plugging in other values too. ...notice anything?:wink:
sorry, yep your right!
Related Threads on Trig identity question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
