Homework Help: Trig Integration
  1. Jun 18, 2009 #1
    Mentallic
    [tex]\int{\frac{sin^3x}{cos^2x}dx}[/tex]
    3. The attempt at a solution
    I've tried converting the trigs into more useful forms, but didn't find anything helpful there.
    Some help please?
  3. Jun 18, 2009 #2
    Cyosis
    Write the integrand in terms of a tangent then use the identity [itex]1+\tan^2 x=\sec^2 x[/itex]. Can you take it from there?
    Edit: Substituting [itex]\sin^2 x=1-\cos^2 x[/itex] is easier.
  4. Jun 18, 2009 #3
    lanedance
    hey Mentallic, have you tried cos^2(x) = 1-sin^2(x) and some subsititution from there?
  5. Jun 18, 2009 #4
    Mentallic
    Using [itex]1+tan^2x=sec^2x[/itex]
    [tex]\int{(sec^2x-1)(sinx)dx}[/tex]
    [tex]=\int{tanxsecx-sinx}dx[/tex]
    I get stuck here with the tanxsecx part...
    with [itex]cos^2x=1-sin^2x[/itex]
    [tex]\int{\frac{sin^3x}{1-sin^2x}dx}[/tex]
    [tex]\int{\frac{-sinx(1-sin^2x)+sinx}{1-sin^2x}dx}[/tex]
    [tex]\int{-sinx+\frac{sinx}{1-sin^2x}dx}[/tex]
    I'm just heading in the same direction as before... I must be using these identities in the wrong way. Any other hints?
  6. Jun 18, 2009 #5
    Ok, you are heading to the right direction:
    [tex]\int{-sinx+\frac{sinx}{1-sin^2x}dx}=[/tex]
    [tex]=\int{-sinxdx}+\int{\frac{sinx}{1-sin^2x}dx}=[/tex]
    [tex]=cosx+\int{\frac{sinx}{cos^2x}dx}[/tex]
    I. Use the substitution method.
    [itex]t=cosx[/itex], so that
    [tex]dt=-sinx[/tex]
    or
    use the method integration by parts to solve the remaining integral:
    [tex]\int u\, dv=uv-\int v\, du.\![/tex]
    [tex]u=sinx , dv=\frac{1}{cos^2x}dx[/tex]
    Good luck.
  7. Jun 18, 2009 #6
    Cyosis
    This is correct, the rest is overly complicated and only makes things harder. If you knew your trig derivatives by heart you would instantly recognize the primitive.
    [tex]\tan x \sec x=\frac{\sin x}{\cos^2 x}[/tex]
    You know that the derivative of the cosine is the negative sine. This makes it clear you want to make a substitution involving cos.
    That is a very poor identity to use since you complicate the denominator this way. I told you [itex]\sin^2x=1-\cos^2x[/itex] would be easier, because then you would get that term in the numerator which makes things easy to split.
  8. Jun 19, 2009 #7
    Mentallic
    Ahh I see what you were intending now. I was able to convert
    [itex]\int{\frac{sinx}{cos^2x}dx}[/itex] into [itex]-\int{u^{-2}}du[/itex] where [itex]u=cosx[/itex]
    Thanks a lot for the help.
  9. Jun 19, 2009 #8
    Cyosis
    Yep that's it. Secondly I would advice you to also memorize the derivatives of the sec, csc and cot functions. It will make spotting primitives a lot easier. For example:
    [tex]
    \frac{d \sec x}{dx}=\sec x \tan x
    [/tex]
    This would have allowed you to solve your integral almost instantly.
  10. Jun 19, 2009 #9
    Mentallic
    Oh yeah :biggrin: I suppose the best tool in integration is rididculous amounts of practice to remember all possible results I would be asked in an exam hehe.
  11. Jun 19, 2009 #10
    Cyosis
    Experience is certainly a great asset when it comes to finding primitives. To solve the more common integrals you should be proficient in:
    Knowing basic derivatives
    Partial fractions
    Completing the square
    Trigonometric substitutions
    Hyperbolic substitutions
    Knowing these together with the basic integral theorems, such as integration by parts, will allow you to handle all the integrals they will throw at you during an exam.
  12. Jun 19, 2009 #11
    Mentallic
    Thanks for your advice and help Cyosis :smile:
Loading...
