• Support PF! Buy your school textbooks, materials and every day products Here!
Trig Limits
i understand the basic lim x->0 (sinx/x) = 1 thimg, but if its something more advanced im clueless, such as:
lim 3x^2/(1-cosx) where x->0
how would you solve this one, or something like lim sin(cosx)/cosx where x-> pi/2?
thanks for any help :smile:
Answers and Replies
Two ways, the first is more general, the second is more useful in this case.
1) Whenever you have a limit that turns into 0/0, use L'Hospital's Rule: Take the derivative of both the numerator and the denominator, then take your limit. So [tex] \lim_{x \rightarrow 0} \frac{3x^2}{1-cosx}= \lim_{x \rightarrow 0} \frac{6x}{sinx} [/tex], which gives 0/0, so do it again: [tex] \lim_{x \rightarrow 0} \frac{6x}{sinx} = \lim_{x \rightarrow 0} \frac{6}{cosx} = 6 [/tex].
2) Use the series expansion for cosine about zero: [tex] cosx = 1 -(1/2!)x^2+(1/4!)x^4-... [/tex]. Take the leading two terms in the cosine expansion and your limit turns into [tex] \lim_{x \rightarrow 0} \frac{3x^2}{1-cosx} = \lim_{x \rightarrow 0} \frac{3x^2}{(1/2)x^2} =2*3=6 [/tex].
-Dan
VietDao29
1,423
If you haven't covered L'Hopital rules yet, I'd suggest another way. By the way, L'Hopital's rule is overkill, you should not use it, though...
Since you know that:
[tex]\lim_{x \rightarrow 0} \frac{\sin x}{x} = 1[/tex]. You should change your limit a little to have the form above:
[tex]\lim_{x \rightarrow 0} \frac{3x ^ 2}{1 - \cos x}[/tex]
Since you want sin x, and you have (1 - cos x) in the denominator, you may want to multiply both numerator, and denominator by (1 + cos x)
[tex]\lim_{x \rightarrow 0} \frac{3x ^ 2}{1 - \cos x} = \lim_{x \rightarrow 0} \frac{3x ^ 2 (1 + \cos x)}{(1 + \cos x) (1 - \cos x)} = \lim_{x \rightarrow 0} \frac{3x ^ 2 (1 + \cos x)}{\sin ^ 2 x} = 3 \lim_{x \rightarrow 0} \left( \frac{x}{\sin x} \right) ^ 2 (1 + \cos x)[/tex]
Now can you go from here?
[tex]\lim_{x \rightarrow \frac{\pi}{2}} \frac{\sin (\cos x)}{\cos x}[/tex]
When [tex]x \rightarrow \frac{\pi}{2}[/tex], [tex]\cos x \rightarrow 0[/tex], right? So you'll have the indeterminate form 0 / 0, right?
Now, if you let u = cos x, so as x tends to [tex]\frac{\pi}{2}[/tex], u will tend to 0, right?
So you'll have:
[tex]\lim_{x \rightarrow \frac{\pi}{2}} \frac{\sin (\cos x)}{\cos x} = \lim_{u \rightarrow 0} \frac{\sin u}{u} = ?[/tex]
Can you go from here? :)
Related Threads on Trig Limits
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
