• Support PF! Buy your school textbooks, materials and every day products Here!
Trig problem
  • Thread starter ooovooos
[PLAIN]http://img530.imageshack.us/img530/5062/dgsdgsdgs.jpg [Broken]
what is h??
tan x = sin x/ cos x
cos x = adj/hyp
sin x = opp/hyp
uh im not even really sure where to start. i havent done trig in a really really long time. im guessing you have to use trig. and i set the area under the dotted triangle as x so the entire bottom length would be 100 + X but im not even sure how that helps.
Answers and Replies
Borek
Mentor
28,444
2,840
Add one unknown - length of the leg adjacent to 60° angle. You have two unknowns - h and the leg. Can you express tangents of both angles using these unknowns (and known length 100)?
^ no offense but the "clue" you gave was so small that i'm just back where I started...confused...didnt really push me in any particular direction. -_-
tan 30 = h / (100 + x) = sqrt 3 over 3
tan 60 = h / x = sqrt 3?
i dont see how that helps.
i tried solving for h using the one that equals tan 60..that turns out to be x times sqrt 3...i plugged that into the first equation...and that just seems way too complicated. I did this type of question two years ago in HS...i am so sure this question isnt supposed to be this complicated.
Is this the equation you got?
[tex]\frac{x\sqrt{3}}{100 + x} = \frac{\sqrt{3}}{3}[/tex]
It requires a bit of algebra, but it's not bad.
Borek
Mentor
28,444
2,840
You got to two equations in two unknowns, and you are solving them using correct approach. Just don't give up.
Related Threads on Trig problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
