Trig Problem
  • Thread starter sunny304
sunny304
Hey guys, not touched any mathematics in almost 5 years and im just getting back into it, been going well so far but hit a hurdle with this, I presume its some gaps in my knowledge.
So been at this for about an hour, got the first one, no clue on the second, can anyone offer assistance?
K(-2, 7), L(8, 7), M(14, -1), N(4, -1) are the vertices of a quadrilateral.
Calculate the angle that the lines LN and KM make with the x-axis.
For LN I worked out the gradient/slope of the line and used the inverse of tan to come to the solution 63.4 which seems to be correct. However with KM employing the same method doesn't produce the correct result.
Thanks for any help.
Answers and Replies
berkeman
Mentor
63,232
14,177
For KM, the slope is just negative, right? That will give you a negative theta when you use the tan^-1 function. What value did you get?
sunny304
Ah its just clicked, the x axis can't be more than 180 degrees, so when I get the negative theta, I just subtract from 180 to get the angle. So Simple.
Thank you
berkeman
Mentor
63,232
14,177
Thank you
Yes, but be careful to look at what the problem question is -- it can vary depending on the question. Sometimes they will want the negative angle as the answer. Other times they will want you to subtract the angle from 180. Just depends on how the question is worded.
Suggested for: Trig Problem
  • Last Post
  • Last Post
  • Last Post
