Solving Trig Substitution: \int cos^2x tan^3xdx
In summary, the first step is to split the integral into components and then substitute the correct u values. Next, backsubstitute and tack on the C at the end.
suspenc3
402
How would I go about solving this:
[tex]\int cos^2x tan^3xdx[/tex]..all i did so far ..
[tex]\int cos^2x tanx(tan^2x)[/tex]
[tex][[ \frac{1}{cosx}^2 -1] = tan^2x[/tex]
so...
[tex] \int cos^2x[[ \frac{1}{cosx}]^2-1]tanx[/tex]
is this right so far...now what?
Another way would be using tan(x) = sin(x)/cos(x), like:
[tex]
\cos ^2 x\tan ^3 x = \cos ^2 x\frac{{\sin ^3 x}}
{{\cos ^3 x}} = \frac{{\sin ^3 x}}
{{\cos x}}
[/tex]
Now if you use sin³x = sin²x.sinx and convert the sin²x to 1-cos²x, I smell a good substitution coming :smile:
Your method was fine as well though, continuing could give:
[tex]
\cos ^2 x\tan ^3 x = \cos ^2 x\left( {\sec ^2 x - 1} \right)\tan x = \tan x - \cos ^2 x\tan x = \tan x - \sin x\cos x
[/tex]
ohh..ok so i got as far as [tex]\int \frac{sinx - sinxcos^2x}{cosx}[/tex]
Well, you can do many things with that. My choice would be rewriting as:
[tex]
\int {\frac{{\sin x - \sin x\cos ^2 x}}
{{\cos x}}dx} = \int {\frac{{\sin x\left( {1 - \cos ^2 x} \right)}}
{{\cos x}}dx}
[/tex]
Do you see a nice substitution now?
yes I get [tex]ln|cosx| - \frac{1}{2}cos^2x + C[/tex]
You should check that again (signs?)
im having trouble with another..ive worked it down..but i think its wrong..
[tex] \int cot^5xsin^4xdx[/tex]
[tex] \int \frac{cos^5x}{sinx}dx[/tex]...would i just simplify the top to cos^2x(cos^2x)(cosx)?
Sure, and switch each cos²x to 1-sin²x so you can substitute y = sin(x).
Watch out though: your last one wasn't correct. I find:
[tex]
- \ln \left( {\cos x} \right) - \frac{{\sin ^2 x}}
{2} + C
[/tex]
yea i messed up the signs thanks|
Ok, the other one should be fine now?
[tex]
\int {\frac{{\cos ^5 x}}
{{\sin x}}dx} = \int {\frac{{\left( {1 - \sin ^2 x} \right)^2 }}
{{\sin x}}\cos xdx}
[/tex]
Perfect for y = sin(x).
how about [tex]\int sec^6tdt[/tex]
where to start?
sec^2t(sec^2t)(sec^2t)?
where to start?
The first thing you want to do is split up [tex]\int sec^6tdt[/tex] into components so some parts of it will cancel.
You're on the right track, remember that sec^2t = 1 + tan^2t, and make a u substitution. If you go about it correctly, one of those sec^2ts will cancel and you will have the integral in terms of u. Once you get to that step, backsubstitute and tack on the C at the end.
Best of luck.
Uhm, sec6x = sec6x - sec4x + sec4x - sec2x + sec2x = sec4x (sec2x - 1) + sec2x (sec2x - 1) + sec2x.
And you should also notice that:
[tex]\frac{d}{dx} \tan x = \sec ^ 2 x[/tex]
I'll give you an example.
Example:
[tex]\int \sec ^ 4 x dx = \int \left( \sec ^ 4 x - \sec ^ 2 x + \sec ^ 2 x \right) dx = \int \left( \sec ^ 2 x (\sec ^ 2 x - 1) + \sec ^ 2 x \right) dx[/tex]
[tex]= \int ( \sec ^ 2 x \tan ^ 2 x ) dx + \int \sec ^ 2 x dx = \int \tan ^ 2 x d(\tan x) + \int \sec ^ 2 x dx = \frac{\tan ^ 3 x}{3} + \tan x + C[/tex]
Can you go from here? :)
1. What is trig substitution?
Trig substitution is a method used to solve integrals involving trigonometric functions by substituting trigonometric identities in place of the original variables.
2. How do I know when to use trig substitution?
Trig substitution is typically used when the integral involves a radical expression or a quadratic expression that cannot be solved using basic integration techniques.
3. How do I solve \int cos^2x tan^3xdx using trig substitution?
To solve this integral, we use the substitution u = tanx, which allows us to express cos^2x in terms of u. We then use trigonometric identities to simplify the integral and solve for u. Finally, we substitute back in the original variable x to get the final answer.
4. What are the most common trigonometric identities used in trig substitution?
The most common identities used in trig substitution are sin^2x + cos^2x = 1, tan^2x + 1 = sec^2x, and 1 + cot^2x = csc^2x.
5. Are there other methods for solving integrals involving trigonometric functions?
Yes, there are other methods such as partial fraction decomposition, integration by parts, and using trigonometric substitutions that do not involve substituting trigonometric identities. However, trig substitution is a useful and commonly used method for solving integrals involving trigonometric functions.
