• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Triginometry , algebra help
  • Thread starter tweety1234
1. Homework Statement
In △ABC, AB=(2-x) cm, BC=(x+1) cm and ∠ABC=120°:
(a) Show that AC^2=x^2-x+7.
(b) Find the value of x for which AC has a minimum value
3. The Attempt at a Solution
I am having trouble with part 'b'
am suppose to complete the square , but I dont seem to get the right answer.
[tex] x^2 -x +7 =0 [/tex]
[tex] x^2 -x = -7 [/tex]
[tex] (x- \frac{1}{2} )^2 = -7 + \frac{1}{4} [/tex]
[tex](x- \frac{1}{2} )^2 = \frac{-27}{4} [/tex]
[tex] x- \frac{1}{2} = -\frac{\sqrt27}{2}[/tex]
and than am I suppose to solve for x ? what does it mean by minimum value?
tiny-tim
25,790
246
uhh? :confused: where did "=0" come from??
just minimise (x - 1/2)2 + 27/4 :wink:
I dont understand what you mean by 'minimise' ? [tex] \frac{1}{4} + \frac{27}{4} = 7 [/tex]
x=7?
tiny-tim
25,790
246
Find the value of x for which (x - 1/2)2 + 27/4 is a minimum … what is that minimum? :smile:
IS the minimum 27/4 , when x = 1/2?
tiny-tim
25,790
246
Mentallic
3,797
94
This step is not correct as taking the square root of a negative number (right hand side of equation) results in complex, imaginary numbers; not the negative square root as you've done. Since x is imaginary, it means that [tex]x^2-x+7 \neq 0[/tex]
And of course, you've already seen that the minimum value is 27/4 which is more than 0.
Related Threads for: Triginometry , algebra help
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
