Finding the Minimum Value of AC in a Triangle with Given Side Lengths
  • Thread starter tweety1234
  • Tags
    Algebra
In summary, in triangle ABC, the sides are given as AB = 2-x cm, BC = x+1 cm, and angle ABC = 120°. Part (a) requires showing that AC^2 = x^2-x+7. In part (b), the task is to find the value of x for which AC has a minimum value. Completing the square is necessary, and the minimum value is found to be 27/4 when x = 1/2. However, it is important to note that the step of taking the square root of a negative number is incorrect and leads to imaginary solutions.
tweety1234
112
In △ABC, AB=(2-x) cm, BC=(x+1) cm and ∠ABC=120°:
(a) Show that AC^2=x^2-x+7.
(b) Find the value of x for which AC has a minimum value
I am having trouble with part 'b'
am suppose to complete the square , but I don't seem to get the right answer.
[tex] x^2 -x +7 =0 [/tex]
[tex] x^2 -x = -7 [/tex]
[tex] (x- \frac{1}{2} )^2 = -7 + \frac{1}{4} [/tex]
[tex](x- \frac{1}{2} )^2 = \frac{-27}{4} [/tex]
[tex] x- \frac{1}{2} = -\frac{\sqrt27}{2}[/tex] and than am I suppose to solve for x ? what does it mean by minimum value?
uhh? :confused: where did "=0" come from??
just minimise (x - 1/2)2 + 27/4 :wink:
I don't understand what you mean by 'minimise' ? [tex] \frac{1}{4} + \frac{27}{4} = 7 [/tex]
x=7?
Find the value of x for which (x - 1/2)2 + 27/4 is a minimum … what is that minimum? :smile:
IS the minimum 27/4 , when x = 1/2?
Yup! :biggrin:
That's what completing the square is all about! :wink:
This step is not correct as taking the square root of a negative number (right hand side of equation) results in complex, imaginary numbers; not the negative square root as you've done. Since x is imaginary, it means that [tex]x^2-x+7 \neq 0[/tex]
And of course, you've already seen that the minimum value is 27/4 which is more than 0.
1. What is the difference between trigonometry and algebra?
Trigonometry is a branch of mathematics that deals with the study of triangles and their properties, while algebra is a branch of mathematics that deals with the manipulation and solving of equations. Trigonometry is often used to solve problems involving angles and distances, while algebra is used to solve problems involving unknown quantities.
2. How are trigonometric functions used in real life?
Trigonometric functions, such as sine, cosine, and tangent, are used in a variety of real-life applications, such as navigation, engineering, and architecture. For example, the sine function is used in surveying to measure the height of buildings, and the tangent function is used in construction to determine the slope of a roof.
3. What are the basic trigonometric identities?
The basic trigonometric identities are sine squared plus cosine squared equals one, tangent equals sine over cosine, and cotangent equals cosine over sine. These identities are used to simplify trigonometric expressions and solve equations involving trigonometric functions.
4. How do you solve a trigonometric equation?
To solve a trigonometric equation, you first need to isolate the trigonometric function on one side of the equation. Then, you can use the inverse trigonometric functions, such as arcsine, arccosine, and arctangent, to find the value of the angle. Finally, you can check your solution by substituting the angle back into the original equation.
5. What are the applications of algebra in science?
Algebra is used in various scientific fields, such as physics, chemistry, and biology. In physics, algebra is used to calculate the motion of objects and solve problems involving forces and energy. In chemistry, it is used to balance chemical equations and calculate concentrations. In biology, algebra is used to model population growth and analyze data from experiments.
  • Precalculus Mathematics Homework Help
