Solving Trigonometric Equation with Cosine and Sine Identities
In summary, the conversation was about solving the equation \frac{7}{4}-2sin(x)-cos^2(x)=0 using common identities and the quadratic formula. After some trial and error, the solution was found to be x=\pi/6+2\pi n and x=5\pi/6+2\pi n, where n is an integer. The conversation also touched on the importance of using consistent units (either degrees or radians) when solving equations.
James889
192
Hi,
I would like som help on this one:
Give all the real soulutions to the equation
[tex]\frac{7}{4}-2sin(x) - cos^2(x) = 0[/tex]
i tried the common identities, like replacing [tex]cos^2(x)[/tex] with [tex]1-sin^2(x)[/tex]
any ideas?
Well you picked the right identity. Why did you stop? :tongue:
You'll have a quadratic in sinx which you need to solve, and remember that the range of sinx is between -1 and 1 so scrap any solutions outside this range as they're not real.
Hi James889! :smile:
Good! :smile:
and now put sinx = y, and solve. :wink:
Good! :smile:
Thank you Flounder :),
So something along the lines of:
[tex]\frac{7}{4} -2sin(x)-cos^2(x) = 0[/tex]
[tex]\frac{7}{4} -2sin(x)-1-sin^2(x) = 0 [/tex]
[tex]\frac{3}{4}-2sin(x)-sin^2(x)=0 [/tex]
substitute x = sin x
[tex]x^2 -2x -\frac{3}{4} = 0[/tex]
[tex]-\frac{1}{2} \pm \sqrt{\frac{4+4*\frac{3}{4}}{2}}[/tex]
not fishy enough
nooo, not fishy enough :wink:
i] you got a minus sign wrong
ii] you still need to convert back
iii] using the same letter to mean two different things ("substitute x = sin x") is a really mammalian thing to do. :rolleyes:
:frown:
Hm, ye i think i messed up the quadratic formula i think it should be like this [tex]-x^2 -2x +\frac{3}{4} = 0[/tex]
Giving me
[tex]\frac{1}{2} \pm \sqrt{\frac{(-2)^2+4*\frac{3}{4}}{2}}[/tex]
hm, convert back?
James889 said:
:frown:
Giving me
No, almost completely wrong. :redface:
hm, convert back?
Yes, that'll be sinx, not x.
Tim, tim, tim you're breaking my balls here...
one more try...deep breath
[tex]\frac{2}{2}\pm\sqrt{\bigg(\frac{-2}{2}\bigg)^2 -3/4}[/tex]
So [tex]x = -0.5[/tex] but [tex]sin^{-1}(-0.5) = -30[/tex] that in the original equation gives 2
but [tex]sin^{-1}(0.5) = 30[/tex] gives the correct answer of 0.
Mysteriously, that's the right answer, but I don't know how you got it from -x2 - 2x + 3/4 = 0 :confused:
Nor how you get -0.5 from it :redface:
Obviously the quadratic formula method isn't working too well...
How about this?
[tex]4x^2+8x-3=0[/tex] (by multiplying through by -4)
Now, see if you can factorize this, because it can be factorized neatly.
How about this?
[tex](-2x+3)(2x-1)[/tex]
But i don't get it, what was wrong with using the formula?
uhh? (-2x+3)(2x-1) = -4x2 + 8x - 3 :confused:
(and your formula started with b/2a instead of -b/2a)
As tiny-tim has said, you didn't factorize correctly. Try again and check your solution by expanding!
You want:
[tex]4x^2+8x-3[/tex]
and you have:
[tex](-2x+3)(2x-1)=-4x^2+8x-3[/tex]
Hm,
Is there some sort of trick when factorizing these kinds of expressions ?
i have only gone by trial and error so far, this could take a while :/
I wouldn't bother to try to factor a quadratic equation unless the result is blindingly obvious …
it's quicker and safer to use the (-b ± √etc) formula. :wink:
I tried but it turned out fishy ;)
yes, i had [tex] -x^2 -2x +\frac{3}{4} = 0[/tex]
-b in this case would be [tex]\frac{-(-2)}{2}[/tex]
uhhh? :redface: what's wrong with being fishy? :frown:
Yes, you've been very messy :rolleyes:, but you've got the right result at last: 1 ± 1/2. :smile:
ok, so if sinx = 1 ± 1/2, x = … ?​
[tex]x = 30^{\circ}[/tex]
Is happy tim ? :)
James889 said:
Is happy tim ? :)
i'm always happy! o:)
mmm … so all the real solutions are … ? :smile:
Oh, dang i forgot about that...
[tex]\frac{\pi}{6} +n*2\pi[/tex]
[tex]30^{\circ} +n*2\pi[/tex]
oh come on
you can't mix degrees and radians, can you?
and anyway, 30º isn't the only solution ≤ 360º. :wink:
tiny-tim said:
oh come on
Heh, i knew that:uhh: i was just, um testing you :rolleyes:
of course, silly me, we have [tex]sin(\pi-\pi/6)[/tex] as a solution aswell.
ok, well i assume you're still testing me, so i think that would be :rolleyes:
5π/6 :smile:
Congrats tiny-tim, I think you passed the test! :wink:
I'm just being a little picky here: when you say another solution is [itex]sin(5\pi/6)[/itex] remember that the original equation was [itex]-sin^2x-2sinx+3/4=0[/itex] and the solutions to this equation are x=... so don't say a solution is [itex]sin(5\pi/ 6)[/itex] but rather just [itex]5\pi /6[/itex] :smile:
Else if you were to test your solution, you'd be solving this: [tex]-sin^2(sin(5\pi/ 6))-2sin(sin(5\pi/ 6))+3/4[/tex] which does not equal 0 thus it's not a solution.
Ok so now you have the two solutions for [itex]0\leq x\leq 2\pi[/itex]. [itex]x=\pi/6[/itex] and [itex]x=5\pi/6[/itex]. Can you express all of the multiple values of these 2 solutions in just 1 equation? (I'm assuming that's how you're expected to show the values)
e.g.
[itex]x=\pi /6 +2\pi n[/itex]
and
[itex]x=5\pi /6 +2\pi n[/itex]
n being all integers.
Can you combine these 2 equations into 1?
1. What are sine and cosine identities?
Sine and cosine identities are mathematical rules that allow us to manipulate and simplify trigonometric expressions involving sine and cosine functions. These identities are derived from the properties of right triangles and can be used to solve trigonometric equations.
2. How do I solve a trigonometric equation using cosine identities?
To solve a trigonometric equation using cosine identities, you need to first identify if the equation contains only cosine functions. If it does, you can use the Pythagorean identity (cos²θ + sin²θ = 1) or one of the other cosine identities (such as double angle or half angle identities) to simplify the equation and solve for the unknown variable.
3. Can I use sine identities to solve a trigonometric equation?
Yes, you can use sine identities to solve a trigonometric equation if the equation contains only sine functions. Similar to solving with cosine identities, you can use the Pythagorean identity or other sine identities to simplify the equation and find the solution.
4. What is the difference between solving a trigonometric equation with cosine identities and with sine identities?
The main difference between solving with cosine identities and with sine identities is the type of trigonometric functions involved in the equation. Cosine identities are used for equations with only cosine functions, while sine identities are used for equations with only sine functions. However, both types of identities follow similar rules and principles of solving trigonometric equations.
5. Can I use both cosine and sine identities in one trigonometric equation?
Yes, in some cases, it is necessary to use both cosine and sine identities to solve a trigonometric equation. This usually happens when the equation contains both cosine and sine functions or when the equation cannot be simplified using only one type of identity. In these cases, you can use both identities to simplify the equation and find the solution.
  • General Math
