Trigonometric Equation Solving: Cosine and Sine Identities for Homework
In summary, the conversation discusses solving the equation ## \cos(x) + \cos(3x) = \sin(x) + \sin(3x)## using the triple angle formulas and the Pythagorean trig identity. The correct solutions are found to be ##x = \frac{\pi}{2} + \pi n, \frac{\pi}{8} + \pi n, \frac{-3\pi}{8} + \pi n##. It is also suggested to use the identity ##\cos(2x-x)+\cos(2x+x)=\sin(2x-x)+\sin(2x+x)## to solve the equation.
Alettix
177
The following equation is to be solved for all x:
The tripple angle formulas:
## \cos(3x) = 4\cos^3(x) - 3\cos(x) ##
##\sin(3x) = 3\sin(x) - 4\sin^3(x) ##
The Pythagorean trig identity:
## \sin^2(x) + \cos^2(x) = 1 ##
Applying the tripple angle identities we have:
## \cos(x) + 4\cos^3(x) - 3\cos(x) = \sin(x) + 3\sin(x) - 4\sin^3(x) ##
Simplifying:
## 4\cos^3(x) - 2\cos(x) = 4\sin(x) - 4\sin^3(x) ##
## 2\cos(x)(2\cos^2(x) - 1) = 4\sin(x)(1 - \sin^2(x) ##
With the Pythagorean identity:
## \cos(x)(\cos^2(x) - \sin^2(x)) = 2\sin(x)\cos^2(x)##
Now, from this it look as if ##cos(x) = 0## should be a solution, which yields ##x_1 = \pi n## where ##n## is an integer. Continuing with the rest:
## (\cos^2(x) - \sin^2(x)) = 2\sin(x)\cos(x)##
## \cot(x) - \tan(x) = 2 ##
## \tan^2(x) + 2\tan(x) -1 =0##
Solving the second degree equation yields ##\tan(x) = -1 \pm \sqrt{2} ##, which gives ##x_2 = \frac{\pi}{8} +\pi n## and ##x_3 = \frac{-3\pi}{8} +\pi n##.
Now the only problem is that none of these solutions is right! Here https://www.desmos.com/calculator/dvbz4qpadt I plotted the functions and searched their intersection, and it doesn't match my solution. Where is my misstake? How can I solve the equation properly?
Thank you very much in advance!
Are you sure that ##\cos(n\pi) = 0##?
Likes Alettix
Oh noo! That's totally wrong! It yields ##x_1 = \frac{\pi}{2} + \pi n## of course!
Yep. And now it seems the graph agrees with your solutions!
And now I see that the solutions are fine...Such a stupid misstake!
Thank you for your help!
Fwiw, you could have gone
##2\cos(2x)\cos(x)=2\sin(2x)\cos(x)##
##\cos(x)=0## or ##\tan(2x)=1##.
Likes Alettix and SammyS
What is a trigonometric equation?
A trigonometric equation is an equation that contains trigonometric functions such as sine, cosine, tangent, etc. These equations involve the relationship between the sides and angles of a triangle.
What is the difference between a trigonometric equation and a trigonometric identity?
A trigonometric equation is an equation that can be solved to find specific values for the variables, while a trigonometric identity is an equation that is true for all values of the variables.
How do you solve a trigonometric equation?
To solve a trigonometric equation, you need to use trigonometric identities, properties, and algebraic techniques. You can also use a calculator to find approximate solutions.
Can a trigonometric equation have more than one solution?
Yes, a trigonometric equation can have multiple solutions. This is because the trigonometric functions are periodic, meaning they repeat their values at regular intervals.
What are the applications of trigonometric equations?
Trigonometric equations are widely used in fields such as engineering, physics, and navigation. They are used to model and solve real-world problems involving angles and distances, such as finding the height of a building or the trajectory of a projectile.
