Why do we assume certain values for theta and x in trigonometric substitutions?
In summary, the author assumes that ##\tan{\theta}## is positive in order to eliminate the absolute value bars and make the integral easier to solve. This assumption allows for general steps to be taken, and the answers are similar whether ##\tan{\theta}## is positive or negative. In the case of having limits of integration, the steps are explained well on the page. However, there is confusion regarding the assumption of ##\theta## and ##x##, and it may be helpful to restrict ##\theta## to the first and fourth quadrant or assume that ##x## is positive.
PFuser1232
479
http://tutorial.math.lamar.edu/Classes/CalcII/TrigSubstitutions.aspx
In example one, the author drops the absolute value bars and makes the following statement:
"Without limits we won’t be able to determine if ##\tan{\theta}## is positive or negative, however, we will need to eliminate them in order to do the integral. Therefore, since we are doing an indefinite integral we will assume that ##\tan{\theta}## will be positive and so we can drop the absolute value bars."
Why should we assume that ##\tan{\theta}## will be positive?
Assuming it to be positive allows you to go through the general steps. You could also have assumed it to be negative, or worked out both cases. In the end, you'll see that the answers are very similar.
In the case that you have a limits of integration, I feel like this page explains the steps well.
But isn't the indefinite integral the most general antiderivative? It would therefore make sense to assume that ##x## can take on any value. Can we avoid this problem by restricting ##\theta## in the first and fourth quadrant only? This would work for all ##x##.
In the first example the author implicitly assumes that ##\theta## lies in ##(0,\frac{\pi}{2})## and that ##x## is positive. The right triangle wouldn't make sense otherwise. This is getting really confusing!
What is a trigonometric substitution?
A trigonometric substitution is a method of integration in calculus that involves using a trigonometric function to replace a complicated algebraic expression in an integral. This substitution allows for the integral to be simplified and solved using known trigonometric identities.
When should I use a trigonometric substitution?
A trigonometric substitution is most useful when the integral being solved involves a radical expression, specifically one that contains the terms √(a²-x²), √(a²+x²), or √(x²-a²). These types of integrals can usually be solved using a trigonometric substitution.
What are the most commonly used trigonometric substitutions?
The most commonly used trigonometric substitutions are x = a sin(θ), x = a cos(θ), and x = a tan(θ). These substitutions are used depending on the form of the integral being solved.
How do I know which trigonometric substitution to use?
To determine which trigonometric substitution to use, you must examine the integral and see which substitution will result in the simplest form. For example, if the integral contains √(a²-x²), you would use the substitution x = a sin(θ).
What are some common mistakes to avoid when using trigonometric substitutions?
One common mistake is forgetting to substitute back for the original variable at the end of the problem. It is also important to be aware of the limits of integration and make sure they are properly adjusted after the substitution is made. Another mistake is using the wrong trigonometric function for the substitution. Make sure to carefully examine the integral before choosing a substitution. Finally, it is important to double check the final answer, as trigonometric substitutions can sometimes lead to algebraic errors.
  • Calculus
  • Calculus
