Solve Trigonometry Equation: 4cosec(X) - 3sec(X) = 4cos(2X)
In summary, the conversation revolves around a difficult equation (4cosec(X) - 3sec(X) = 4cos(2X)) that the participants are trying to solve. Different approaches and methods are suggested, but it is ultimately concluded that there are two real solutions to the equation.
truewt
78
Okay guys, this equation is bothering me and I have no idea how to start:
[tex] 4cosec(X) - 3sec(X) = 4cos(2X)[/tex]
Is that first term [itex] 4\csc(x)[/itex]? And what are you trying to do with the equation, solve it?
Yup, to both queries.
I tried many approaches but can't solve :(
write cosec(x) and sec(x) in terms of cos and sine, then bring the left side to a common denominator.
EDIT: wait...that might get complicated.
I doubt it has "nice" solutions though.
i tried that. It's a damn freaking weird question. I can't solve.
what I will end up with is [tex] 4cos(X) - 3sin(X) = sin(4X) [/tex]
Unfortunately that's probably the nicest form you can get. The right hand side folds up nicely but then you'd have to deal with the 4cos(x) - 3sin(x). I tried expanding cos(2x) but that got nasty quick.
I don't think that statement is correct. There aren't any real solutions.
Hi truewt! :smile:
Hint: write it [tex] \frac{4}{5}cos(X) - \frac{3}{5}sin(X) = \frac{1}{5}sin(4X) [/tex]
Then let sin(Y) = 4/5.
Does that help? :smile:
Being fairly new to trig, I'd like to ask a question based on this question. I'm a hands-on kind of guy, so I take something and just jam a number where x is to see what happens. Let's say we stick 30 (degrees) into it. The left side becomes:
4csc30 - 3sec30 or 4(2) - 3(1.15) = 4.55
The right side becomes:
4cos2(30) = 4(1-2sin^2(30)) = 2
Put them together and you get 4.55 = 2, which is never true. Additionally, I've gone through the trouble of defining everything in terms of sin x, and the two sides of the equation cannot equal. What are we looking for here?
DecayProduct, I assume we're trying to find all values of X that satisfies the equation.
Now if you're trying to imply that there are no real solutions based on substituting one value of X then that's not very reliable. Sure 4.55 =/= 2 but that doesn't really tell us anything except that if x = 30 deg then the equation is not satisfied.
You can only deduce that an equation is not satisfied if you can eliminate the variables and find a contradiction. But what you've done is basically the equivalent of taking any equation, say one involving polynomials, and plugging in a value for x, finding out the two sides don't equal, and claiming that the two sides are not equal. If you claim no solutions, you'll have to find a clear cut contradiction.
I guess you can change the equation to,
[tex] (1/2)*cos^{-1}((4cosec(X) - 3sec(X))/4) = X[/tex]
So let
[tex] f(X) = (1/2)*cos^{-1}((4cosec(X) - 3sec(X))/4)[/tex]
Then use a computer program or any scientific calculator, to find the limit of [tex]f^n(X)[/tex] as n tends to infinity... where [tex]f^n(X) = f(f(f(... n times(f(f(X)))))[/tex]
Why did you pick 30 degrees? This isn't an identity that is asked to be shown but rather a "solve for x" type situation I believe.
30 wasn't all I tried. But it was arbitrary, to see what happens. Please forgive my ignorance when it comes to such things. I don't claim to know enough to say if the equation has a solution or not. But, even if you boil the whole thing down into the rudimentary parts, that is, x's, y's and r's, I can't get the two sides to balance. If you convert all the units in terms of sinx, I can't get it to balance. cos x = sin x(sqrt(1/sin^2 x -1)), and cos 2x = 1-2sin^2 x.
It is a messy bunch of scribbling I have here, but the left still doesn't equal the right. I can't figure how any angle would satisfy it. What gives?
If you have a graphing calculator or computer program, you can just plot the original left side minus the original right side. You will then see that (in the range between 0 and 360 degrees) there are two real solutions.
1. What is the formula for solving a trigonometry equation?
The formula for solving a trigonometry equation is to isolate the variable by using inverse trigonometric functions and applying trigonometric identities.
2. How do I solve a trigonometry equation with multiple trigonometric functions?
To solve a trigonometry equation with multiple trigonometric functions, use the Pythagorean identities and other trigonometric identities to simplify the equation and then isolate the variable.
3. What is the difference between cosecant and secant?
Cosecant (csc) and secant (sec) are reciprocal trigonometric functions. Cosecant is the reciprocal of sine, while secant is the reciprocal of cosine. This means that csc(x) = 1/sin(x) and sec(x) = 1/cos(x).
4. How do I use the double angle formula to solve a trigonometry equation?
The double angle formula states that cos(2x) = cos^2(x) - sin^2(x). To use this formula to solve a trigonometry equation, substitute the expression for cos(2x) and use the Pythagorean identity to simplify the equation.
5. Can I use a calculator to solve a trigonometry equation?
Yes, you can use a calculator to solve a trigonometry equation. However, it is important to understand the steps and concepts behind solving the equation by hand in order to use the calculator effectively and check for any errors in the calculation.
