Trigonometry Function Help
  • Thread starter Buddah
1. Explain why the functions y= cos x and y = sin(x+90) are the same function. Explanation must be detailed include graphs if you wish.
2. Outline why the identities are referred to as Pythagorean identities:
sin²θ + cos²θ = 1
1 + tan²θ = sec²θ
1 + cot²θ = csc ²θ
HELP PLEASEEEE!!!! thanks in advance
Answers and Replies
hunt_mat
1,745
What have you done so far?
I figured out the first one, i now its the same because the cos fucntions is just a shift by 90degrees but i dont know how to explain it.
and am lost for number 2 :(
2. cosine and sine are the x and y-coordinates in the unit circle. At an angle v you can form a triangle with hypothenuse 1 and catheti x and y.
Rewrite the second function y=sin(x+90) using the double angle formula
[tex]
sin (\alpha + \beta) = sin {\alpha}cos {\beta} + cos {\alpha}sin {\beta}
[/tex]
Then the answer to part one of your question should become apparent.
jhae2.718
For part 2, what is the Pythagorean Theorem? Can you write it in terms of sine and cosine?
hunt_mat
1,745
For part 2, think of a right angled triangle with hypotenuse length R say and then write down pythagoras' thoeren and the definition of sin and cos and the answer should become apparent.
HallsofIvy
41,847
964
For the first I would also recommend you draw a right triangle. sin is "opposite side over hypotenuse" and cosine is "near side over hypotenuse". Which side is "opposite" or "near" depends on which angle of the triangle you are using. And what is the relationship between angles in a right triangle?
cos(x) is the x- coordinate
sin(x) is the y- coordinate
Now relate this to the Pythagorean Theorem:cool:
Char. Limit
More to the point, for a circle of radius r, the cosine of a point on that circle is the x-coordinate over r, or x/r. The sine of a point on that circle is the y-coordinate over r, or y/r.
Now, knowing this, and the fact that sin2(z) + cos2(z) = 1, can you show the Pythagorean theorem?
Related Threads on Trigonometry Function Help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
