Trigonometry: Graphing cos
  1. Nov 7, 2015 #1
    Hey I need a second opinion to see if my formulas and calculations are correct. Also I need help with graphing this problem.
    My problem is to find amplitude, period, horizontal shift, vertical translation, step and then graph of:
    y= 2 - (1/3) cos ( πx + (3π/2) ) , -1/4 ≤ x ≤ 15/4
    Using the formula:
    y = A cos ( Bx + C) + D
    A = 2
    B = π
    C = 3/2
    D = 0
    Amplitude: |A| = 1/3
    Period: ((2π) / |B|) = 2
    Horizontal Shift: -C/B = (3/(2π))
    Vertical Translation: D = 0
    Step: ((2π)/2)/B = 1
  3. Nov 7, 2015 #2
    JBA
    All of your data results appear to be correct.
    Mod edit: Some of the results are incorrect.
    What is the problem you are having with the graph?
  4. Nov 7, 2015 #3
    I'm lost on what goes where on the graph.
  5. Nov 7, 2015 #4
    JBA
    Do you know the general shape of a simple y=cos x curve?
    What method are you using to try to create this curve?
    Actually, upon review I have realized that your A = 2 and D = 0 values are in error but your amplitude is correct. Look at all of the equation modifiers again to see if you can identify the correct values for A & D
    Also review your C/B value with respect to π
  6. Nov 7, 2015 #5
    Mark44
    Staff: Mentor
    A is not 2 and D is not 0.
    Your amplitude and period are correct, but the horizontal shift and vertical translation are incorrect. I don't know what "step" means with regard to this problem. Is "step" half a period?
  7. Nov 7, 2015 #6
    Horizontal Shift: -C/B = - (3/(2π))
    I've made adjustments to Horizontal Shift by making it a negative number
    I put Vertical translation as 0 since there is no D in the problem.
    I'm not sure what step is but our teacher told us the formula for it.
    Is there something I am missing to find Vertical translation?
    Is there another name for "Step"?
    The formulas that were given to me for step are different for each function. Sin and Cos is: ((2π)/2)/B, Tan is (π/2)/B
  8. Nov 7, 2015 #7
    JBA
    OK, your problem is thinking that D must be at the end of the equation. Reverse the equation order and see what that makes the value of D be.
  9. Nov 7, 2015 #8
    Mark44
    Staff: Mentor
    No, that's still wrong.
    Still wrong.
    What is B? What is C?
    Yes, there is.
    This is because the period of the basic, untransformed sine and cosine functions is ##2\pi##. The period for the basic tangent function is ##\pi##.
  10. Nov 7, 2015 #9
    I reversed the order and got 2!
    So Vertical Translation = 2
    I found B and C by factoring out p from:
    factored form:
    y= 2 - (1/3) cos ( π ( x + (3/2) )
    from the formula: y = A cos ( Bx + C) + D
    B = π
    C = 3/2
    Formula for Horizontal Shift is - ( C / B )
    (3/2)/(π/1) = 3/(2π)
    I'm trying to find out whats missing, still trying to find. any hints?
  11. Nov 7, 2015 #10
    Mark44
    Staff: Mentor
    Yes
    No, the pattern in your formula is different.
    Formula: y = A cos(Bx + C)
    In your work, you factored out ##\pi## from both terms
    The formula is NOT A cos(B(x + C))
    This formula, which you are blindly applying, is for the equation y = A cos (Bx + C)
    From this formula, what is B and what is C?
  12. Nov 7, 2015 #11
    JBA
    The vertical shift is 2; so now you have everything except a confirmed horizontal shift.
    Actually, you have to think in terms of radians, the simple answer is that C = 3π/2 = 1.5π = 270° such that when x = 0 then cos (0 + 270°) = -1 and with the vertical y offset = 2 the result is 2 -1 = 1 (the minimum height of the oscillation) and when x = .5 then cos (.5 + 1.5)π = 2π = cos 180° =0 and y = 2+0 = 2 (the centerline of the curve oscillation) and when x = 1, cos ( 1 +1.5)π = cos 2.5 = cos 90° = 1 and y = 2+1 = 3 ( the maximum height of the oscillation), etc
  13. Nov 8, 2015 #12
    JBA
    One clarification on the above, all of the above max/ min values of 1 & -1 are before muliplying the results of the cos by 1/3 as required by the total equation so for the purposes of your calculations and graph the results are actually 2 - 1/3 x 1 = 1.666, 2 - 1/3 x 0 = 2 and 2 - 1/3 X -1 = 2 + 1/3 = 2.333.
  14. Nov 8, 2015 #13
    B = πx
    C = 3π/2
    Horizontal Shift = -(3/2)!
    My book says that I have to factor out the coefficient of π before finding amplitude, period, etc.
  15. Nov 8, 2015 #14
    JBA
    B = π not πx
