Homework Help: Trigonometry Limit
  1. Oct 29, 2015 #1
    Find the value of:
    lim x approaches 0 of : (3x - sin 3x) / (x2 sin x)
    2. Relevant equations
    Trigonometry identity
    Limit properties
    No L'hopital rule
    3. The attempt at a solution
    I tried changing sin 3x to -4sin3x + 3 sin x but then I stuck. Is changing sin 3x correct way to start solving the question?
    Thanks
  3. Oct 29, 2015 #2
    Svein
    You do remember that [itex]\lim_{z\rightarrow 0}\frac{\sin(z)}{z}=1 [/itex]?
  4. Oct 29, 2015 #3
    Yes I do but I don't know how to use it to solve this question.
    Dividing all the terms by x resulting in:
    [itex]\lim_{x\rightarrow 0} {\frac{3 - \frac{\sin(3x)}{x}}{x \sin(x)}}[/itex]
    [itex] = \lim_{x\rightarrow 0} \frac{3 - 3}{x \sin(x)}[/itex]
    Then stuck
  5. Oct 29, 2015 #4
    haruspex
    That step is not valid. You cannot take the limit in the numerator only, then in the denominator. The two must be done together.
    I would expand sin() as a power series, keeping two or three terms. Not sure if that would be considered allowable in your context.
  6. Oct 30, 2015 #5
    Sorry that is not allowed. No other way to solve it?
  7. Oct 30, 2015 #6
    Mark44
    Staff: Mentor
    What's the context for this problem? By that, I mean where did you see this problem? The limit is apparently 4.5, but the only way I've been able to get that is by using haruspex's suggestion, in addition to using Excel to approximate the limit.
  8. Oct 30, 2015 #7
    SammyS
    Staff Emeritus
    It does look like your initial approach can get you part way there.
    ##\displaystyle \ \frac {3x-\sin(3x)}{x^2 \sin(x)} = \frac {3x-3\sin(x)+4\sin^3(x)}{x^2 \sin(x)} \ ##
    ##\displaystyle \ =\frac {3x-3\sin(x)}{x^2 \sin(x)} + \frac {4\sin^3(x)}{x^2 \sin(x)} \ ##​
    The limit of the second term is straight forward.
    The first term remains somewhat a problem. Maybe Mark or haruspex has an idea for that.
  9. Oct 31, 2015 #8
    From a book I use in high school. This is the question from exercise in the book. The question says: find the limit of the following, then there are a lot of limit questions, from (a) to (z). One of the question is exactly as I posted. The book doesn't cover about power series and at that point (when I saw that question), I haven't learn about L'hopital rule yet.
    Maybe the question is misplaced, should not be on that part of exercise. I should cover L'hopital rule or power series first before solving that type of question.
    Thanks a lot for all the help
  10. Oct 31, 2015 #9
    Mark44
    Staff: Mentor
    Regarding the first term of what Sammy shows above, the only techniques that I can think of are 1) expanding the sin(3x) term (which would be ##3x - \frac{3x^3}{3!}## plus terms of degree 5 and higher), or 2) using L'Hopital's rule, which has to be applied four times.. Either way gives the result I showed in my earlier post.
Have something to add?
Draft saved Draft deleted
Loading...
