What is the value of n in the identity sin^3xsin3x=\sum^n_{m=0}{}^nC_mcosmx?
In summary: How can i get rid of the...remaining square and third power?You could try using the cosine formulas for the square and third power, like cos(mx)^3 and cos(mx)^2.
  • #106
I like Serena said:
The same r as in the polar coordinates.
It is the distance of point (X, Y) to the origin, where z = X + i Y.
Btw, I used capital letters to distinguish them from the "x" in your equation which is actually phi.
Taking it one step further, you have:
z = r cosx + i r sinx = X + i Y
Do you see now?
Got it now! I would print this disccussion to keep it for my reference. :smile:
So what should be the answer of z3=1?
I like Serena said:
Nice icon! :smile:
So you have not learned yet how to solve cos x = c?
Thanks! :smile:
No, i have not learned the algebraic method. :wink:
  • #108
I like Serena said:
In exponential notation:
z1 = 1
z2 = ei(2/3)π
z3 = ei(4/3)π
In cartesian notation:
z1 = 1
z2 = -½ + i ½√3
z3 = -½ - i ½√3
How did you get
z2 = ei(2/3)π
z3 = ei(4/3)π
:confused:
  • #109
Pranav-Arora said:
How did you get
z2 = ei(2/3)π
z3 = ei(4/3)π
:confused:
What do you get if you substitute them in the equation z3 = 1?
  • #110
Substituting z2, ei2n=1
Substituting z3, ei4n=1
Solving both the equations i get n=0.
But how do you get the solutions?:confused:
  • #111
Ah, I see, there is some confusion about π.
That might explain some of the confusion in the previous posts.
Well, π is π and not n.
See the difference?
It's a bit of a font problem I'm afraid.
  • #112
See the difference?
Okay i again substitute the values,
Substituting z2, ei2[itex]\pi[/itex]=1
Substituting z3, ei4[itex]\pi[/itex]=1
How do you get these solutions? :cry:
  • #113
First you will need to understand why these are solutions.
Can you use Euler's formula to convert them to cosine/sine form?
  • #114
Applying Euler's formula:-
[itex]\Rightarrow[/itex]cos2[itex]\pi[/itex]+isin[itex]\pi[/itex]=1
  • #115
Erm... you did not substitute correctly.
But then, do you understand why this is a solution?
What is cos(2pi)?
  • #116
And then, do you understand why this is a solution?
What is cos(2pi)?
Oops sorry, it should be sin 2pi.
I think this is the solution because if we further solve the sine and cosine we get 1 which is equal to the right hand side of the equation.
cos(2pi) is 1.
  • #117
cos(2pi) is 1.
Exactly! :cool:
What about the other solution?
What is cos(4pi)? And sin(4pi)?
Do you perhaps understand now how to I found these solutions?
  • #118
I like Serena said:
Exactly! :cool:
cos(4pi) is 1 and sin(4pi) is 0, but i still don't understand how you find out the solution? :confused:
  • #119
Try to work backward then.
You already know that 2π is a solution as cos(2π)=1
That means that if 3ϕ= 2π that we have solution, so ϕ= (2/3)π.
  • #120
Due to the periodicity of angles in general we have:
[tex]1 = e^{i \cdot 0} = e^{i \cdot 2\pi} = e^{i \cdot 4\pi} = e^{i \cdot 6\pi} = ...[/tex]
So starting from [itex]z^3 = (e^{i\phi})^3 = e^{i \cdot 3\phi} = 1[/itex]
We find [itex]3\phi = 0[/itex] or [itex]3\phi = 2\pi[/itex] or [itex]3\phi = 4\pi[/itex] or [itex]3\phi = 6\pi[/itex] or ...
This means [itex]\phi = 0[/itex] or [itex]\phi = \frac 2 3\pi[/itex] or [itex]\phi = \frac 4 3 \pi[/itex] or [itex]\phi = \frac 6 3 \pi = 2\pi[/itex] or ...
However, the last solution is just the same as the first solution, being exactly one period along, and the same holds for all the following solutions.
So we only have 3 unique solutions.
  • #121
Sorry for the late reply.
I thought i would post after going through our discussion once again.:smile:
May i know how you get the following relation:-
  • #122
Can you ask your question(s) a bit more specific? :smile:
I'm really not sure what I should explain, and what you already get.
  • #123
Oops sorry! I edited my previous post. :smile:
  • #124
Let's just pick one.
We have because of Euler's formula and the periodicity of sine and cosine:
[tex]e^{i \cdot 6\pi} = \cos 6\pi + i \sin 6\pi = 1 + i \cdot 0 = 1[/tex]
That's all. :smile:
  • #125
So are we done?
  • #126
Pranav-Arora said:
So are we done?
I don't know. :confused:
Are we?
  • #127
Are we?
Yes, i think. :smile:
I would practice complex numbers more and more now.
(Never thought complex numbers would be so interesting:rolleyes:)
