Trigonometric Relations for Line Segments with Fixed and Movable Points
In summary, the conversation discusses how to find the angle θ between two line segments using the coordinates of fixed and movable points. It is shown that the angle is given by the relation θ= π-arccotx-arccot(3-x/2), and the steps to obtaining this relation are discussed through the use of diagrams and identifying slopes.
Nyasha
127
Straight line segments are drawn from the fixed point P1(0,1) and P2(3,2) to the movable point P, with coordinates (x,0)on the positive x-axis.
Assuming that 0 ≤ x ≤ 3, show that the angle θ between the two line segments PP1 and PP2 is given by the relation:
[tex]tan\theta = (3-0)/(2 - 1) = 3/2 [/tex] For PP1
[tex]\tan\theta = (3-x)/(2-0)= (3 - x)/2[/tex] For PP2
[tex]\theta = arctan(3/2) - arctan((3-x)/2)[/tex]
First of all l do not know if l am on the right path and even if l am on the right path l get stuck here. Please help
Hi Nyasha! :smile:
No, that's the line from P1 to P2, not P to P1
I'm not sure either … it's difficult to tell whether you're just guessing …
to make it clear to the examiner that you're not guessing, give the angles or directions names, so you can make it clear which angles you're subtracting from which, and why …
in this case, call (0,0) O, and call (3,0) A, and use OPA = π :wink:
tiny-tim said:
Hi Nyasha! :smile:
What is OPA =π ?
Nyasha said:
What is OPA =π ?
uhh? OPA is the angle OPA, from (0,0) to P to (3,0)
Okay, so any tips on how l prove that θ= π-arccotx-arccot(3-x/2) ? I am really confused/blank on this question.
just draw it … it's obvious! :smile:
Tim l have drawn it but it is still not obvious. I still can't figure out how they came up with the relation θ= π-arccotx-arccot(3-x/2)
waaa!
oh Nyasha …
you missed out poor little P! :cry:
tiny-tim said:
oh Nyasha …
Tim l think l solved it now, l drew a better diagram and then figure out what to do. Here is what l did:
[tex]\theta= ArcCot((x-0)/(0-1)) = ArcCot(-x) = Pi - ArcCot(x)[/tex] This one is the slope for PP1
[tex]\theta = ArcCot((3-x)/(2-0) = ArcCot((3-x)/2)[/tex]
[tex]\theta = Pi - ArcCot(x) - ArcCot((3-x)/2)[/tex] (subtract PP1 from PP2)
Looks good! :biggrin:
1. What is trigonometry?
Trigonometry is a branch of mathematics that deals with the relationships and properties of triangles, particularly right triangles. It involves the study of angles, sides, and trigonometric functions such as sine, cosine, and tangent.
2. What are the six trigonometric ratios?
The six trigonometric ratios are sine, cosine, tangent, cosecant, secant, and cotangent. They represent the ratio of the sides of a right triangle and can be used to solve for missing angles or side lengths.
3. How are trigonometry and geometry related?
Trigonometry is a branch of geometry that focuses on the relationships between angles and sides of a triangle. It uses the principles of geometry to solve problems involving angles and distances.
4. What is the unit circle and how is it used in trigonometry?
The unit circle is a circle with a radius of 1 centered at the origin of a coordinate plane. It is used in trigonometry as a reference to determine the values of trigonometric functions for any angle. The coordinates of points on the unit circle correspond to the values of sine and cosine functions.
5. What are some real-life applications of trigonometry?
Trigonometry has many real-life applications, including navigation, architecture, engineering, and physics. It is used to calculate distances, heights, angles, and forces in various fields, such as surveying, construction, and astronomy.
  • Precalculus Mathematics Homework Help
