Triple integral of sphere
The figure below shows part of a spherical ball of radius 5 cm. Write an iterated triple integral which represents the volume of this region.
http://img19.imageshack.us/img19/9237/sphereu.th.jpg [Broken]
http://img19.imageshack.us/img19/1699/inte.jpg [Broken]
2. Relevant equations
3. The attempt at a solution
I already got A, B, C and D correctly. However when I try E and F to be -3 and -sqrt(25-x^2-y^2) respectively and vice versa, the answer is wrong.. why is this.. what should be E and F then?
gabbagabbahey
Is -3 really the minimum value of z for that volume?:wink:
I guess so... z = -3 is just a plane right... other than that I really don't know what it is
gabbagabbahey
Sure, but the region your interested in lies below the plane z=-3, so z=-3 should be the maximum not the minimum......likewise, the region of interest lies above the spherical surface z=-sqrt(25-x^2-y^2), so that should be the minimum value of z.
Did you try E=-sqrt(25-x^2-y^2) and F=-3?
yes I did and as I said on my original posting "vice versa" and it doesn't work as well..
gabbagabbahey
That's odd; assuming that E and F are the lower and upper limits on z, it should work.....how do you know that it doesn't work? Are you imputing these values into an online submission? Or are you just getting an incorrect final answer for the volume?
yes, into an online submission
and shouldn't it be -sqrt(25-x^2-y^2) instead of -sqrt(25-x^2-z^2)
gabbagabbahey
Hmmm, what were your A,B,C and D?
Are you using the convention that [tex]\int_A^B\int_C^D\int_E^F dzdydx[/tex] means first integrate over z from E to F, then over y from C to D, and finally over x from A to B? Or are you using some other convention?
A = -4
B = 4
C = -sqrt(16-x^2)
D = sqrt(16-x^2)
gabbagabbahey
gabbagabbahey
A = -4
B = 4
C = -sqrt(16-x^2)
D = sqrt(16-x^2)
That looks fine; you are either making a mistake/typo when typing in your E and F values, or the online submission program has a bug
hmm...that's what I thought as well.. but are you sure that E=-sqrt(25-x^2-y^2) and F=-3?
gabbagabbahey
Yes, why wouldn't that be correct? (Unless the volume is supposed to also include the cone that subtends that section of the sphere)
Just making sure, as that's what I had in mind as well.. I'll have to ask my instructors about this then.. thanks for confirming
Hmm.. there's a hint to this question, not sure if it helps
Hint: If you flip this solid upside down, you can view it as an upper portion of a sphere that is centered at the origin.
gabbagabbahey
Hmmm.... maybe they are expecting you to do that (even though it is clearly unnecessary); if so, then z would go from +3 to +Sqrt(25-x^2-y^2), so you could try those as your E and F values
well..it makes no sense at all though... I only have one more chance to get this right
gabbagabbahey
Why doesn't it make any sense? The volume of the spherical section is the same no matter where it is right?...If the problem suggests that you reflect it over the xy plane, then you might as well...
yeah, I just realized that the volume is the same.. thanks for pointing that out.. now the answer is correct
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
