Triple Integral
  • Thread starter dwn
dwn
165
Image attached of problem.
Not sure how this applies.
∫(o to ∞) ∫(0 to 5) ∫(0 to 4) 16xy dydxdz
Below, I have completed the integrations in order (dydxdyz):
∫dy : 8xy2|(0 to 4) = 128 x
∫dx : 64x2 = 64(25) = 1600
∫dz : 1600z| (o to ∞)
Do I set a limit on the integration dz, or set it at infinite?
Answers and Replies
tiny-tim
25,836
251
hi dwn! :smile:
the limits of z depend on x and y
so you must integrate wrt z first (from 0 to … ? :wink:)
Dick
26,263
619
If you want to set this up as a triple integral, then since you are trying to find volume, your integrand should be 1. And I would integrate over dz first. And the upper value of z will correspond to its value on the boundary surface. Then integrate over x and y.
dwn
165
If I want to set this up as a triple integral? Just out of curiosity...what other method? I am going to calculate this using the triple, but I would like to know for my own selfish reasons.
How do I go about finding ;) ? When you say that it depends on x and y....I can't just make it any constant, can I?
Dick
26,263
619
You can also find the volume by integrating (height)dxdy. It's not really a different method, you just aren't writing the z integration out explicitly. Same thing. And the limit of z isn't any constant. It's the value of z on the bounding surface as a function of x and y. Don't think too hard about this.
dwn
165
#smackforehead : just set the integral dz from 0 to z....
Dick
26,263
619
.... means just set the integral dz from z=0 to z=16xy, right?
dwn
165
exactly. So does this "thickheaded" thinking go away at some point? :)
Dick
26,263
619
As far as this topic goes it should be going away already. You seem to be pretty clear on how obvious the answer is.
tiny-tim
25,836
251
hi dwn! :smile:
(just got up :zzz:)
when you perform the first integration (in this case, z) in a triple integral to find a volume,
you are essentially finding the volume of a tall thin square slice of the volume, of sides dx and dy …
its volume obviously is (approximately) dxdy times the height,
ie dxdy times [z(x,y) - zo(x,y)]​
where z = z(x,y) is the equation of the top surface, and z = zo(x,y) is the equation of the bottom surface (in this case, the constant z = 0) :wink:
btw, you will notice that the limits of integration for all variables except the last in a multiple integral will generally not be constants, but will generally depend on the later variables!
Related Threads on Triple Integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
