Triple-integrating a region with no volume
  • Thread starter Icebreaker
  • Tags
    Volume
I'm just saying it's a bad pedagogical practice to automatically assume that those symbols are polar coordinates.In summary, the conversation discusses the computation of a triple integral over a region bounded by a paraboloid and a plane. There is confusion about the use of cylindrical coordinates and the meaning of the function f(r,θ,z). Ultimately, it is clarified that the region is a "cap" and the correct integral is calculated to be 243π/2.
Icebreaker
From Shaum's: Compute the triple integral of [tex]f(r,\theta ,z)=r^2[/tex] over the region [tex]R[/tex] bounded by the paraboloid [tex]r^2=9-z[/tex] and the plane [tex]z=0[/tex]
This has me stumped. The volume bounded by [tex]r^2=9-z[/tex] and [tex]z=0[/tex] is not closed in 3-space. But if they really meant region, triple-integrating a region with no volume gives 0. What should I do?
Isn't th region just the region given by rotating the area bound by
x^2 = 9-z and the x-axis about the z axis. Why isn't that closed?
If we imagine the x-y plane on the floor with the positive z axis coming upwards, it's like integrating over the volume given by putting a cap on the floor.
I tried to attach a graph,but the OS wouldn't let me...:yuck: Matt's right,it is a cap.
Daniel.
Why would we rotate it? r^2 = 9 - z describes a parabolic cylinder.
Nope,a revolution paraboloid around the "Oz" axis...
Daniel.
All I can do is echo the others: z= 9- r2 is a paraboloid, with vertex at (0,0,9), opening downward, and "closing" it at z= 0 certainly does form a closed figure. When z= 0, r2= 9 so r= 3. The integration (in polar coordinates) will be over [itex]0\le \theta\le 2\pi[/itex],[itex] 0\le r \le 3[/itex].
So I must watch out for the "special" variables rho, r, theta and phi, such that the inclusion of one of them will automatically mean polar, spherical or cylindrical coordinates?
Indeed, it should have been specified that cylindrical coordinates were being used.
Icebreaker, use [tex] 9-r^2[/tex] as the upper limit in your integration of f over z.
[Edit: Wait, do you already get the idea? Sorry, if I'm being redundant.]
Thanks to everyone. Yes, I know the idea, but because the question itself did not specify cylindrical coordinates, and that it was amid a bunch of other integrals, I thought they simply replaced the x,y,z axes with r, theta and z. Like one of those "trick" questions where they replace f(x) with x(f).
No, it is not a "trick" question and it does specify that cylindrical coordinates are to be used- your original post said "Compute the triple integral of f(r,θ,z), over the region bounded by the paraboloid and the plane"
What do you think f(r,θ,z) means?
HallsofIvy, perhaps he hasn't had enough exposure to cylindrical coordinates to realize that immediately. :rolleyes:
If "he hasn't had enough exposure" (i like how it sounds),then what is he doing solving integrals with them...??
The way i know these variables,it should have been [itex]f\left(\rho,\varphi,z\right) [/itex].
Daniel.
Why should it necessarily mean that they're using cylindrical coordinates? Just because the variables are called [itex]r[/itex], [itex]\theta[/itex], and [itex]z[/itex] should not imply anything about how they're parameterized with respect to the "real" coordinate axes. The problem, of course, is that the question doesn't give you bounds on [itex]\theta[/itex] unless you know implicitly that you're dealing with cylindrical coordinates (or some similar parameterization).
Now, the fact that the question said that the region was bounded by a paraboloid might be grounds for a guess as to the parameterization...
Sadly lots of us are used to the abuse of mathematics that goes on in undergrad calc (in the US sense) and the courses and books all assume that the second you see r, theta, z, or rho phi theta that you know its polars of some flavour. Just as when they say "find the domain of sqrt(xy)" every undergrad should be able to write the answer down but anyone with an exposure to higher mathematics should be tearing their hair out at the sheer awfulness of it.
f(r,θ,z) is simply a 3 variable function. There's no reason why I must treat it differently than f(a,b,c) or x(s,r,t). The point is that I must GUESS what the question is trying to ask, and that's the problem.
Well, the point is that you're using a book that presupposes you can deduce that it is talking about polar coordinates. As soon as you see these labels you ought to think that's what they mean. There is a reason to suppose it is different from other variables, because in lots of maths people assign explicit meaning to letters, particularly engineering courses: t is time, r is radial distance, theta and phi are angles in the xy plane and from the azimuth.
These are commonly accepted practices, even if some of us agree that it is not necessarily a good thing.
What about the answer? Can I say or no? I've attached a plot. Suppose it's a . . . cone-head cap, whatever. Anyway, I get:
[tex]\int_0^{2\pi}\int_0^3\int_0^{9-r^2} r^3dzdrd\theta=\frac{243\pi}2[/tex]
The function was r^2.
Is that just a typo, or did you calculate the wrong integral?
An infinitesimal volume element is rdr(dtheta)dz in cylindrical polars.
Oh, I remember that. :yuck:
I'm not necessarily crtiticising the textbook at all. It's quite possible that it states at some point that it always refers to a certain parameterization when it uses certain symbols, which is perfectly fine with me, as long as it makes it clear that those symbols aren't parameterized that way a priori.
1. What is triple integration?
Triple integration is a mathematical process used to find the volume of a three-dimensional region. It involves integrating a function over three variables, typically denoted as x, y, and z.
2. How is triple integration different from double integration?
Double integration is used for finding the area of a two-dimensional region, while triple integration is used for finding the volume of a three-dimensional region. The main difference is that triple integration involves integrating over three variables instead of two.
3. What is a region with no volume?
A region with no volume is a three-dimensional space that does not contain any points. This could be a theoretical concept or a physical space that has been defined as having no volume.
4. Why would someone want to triple integrate a region with no volume?
Triple integrating a region with no volume may be used as a mathematical exercise or to solve theoretical problems. It can also be used to prove certain mathematical principles or to evaluate complex equations.
5. Are there any real-world applications for triple integration of a region with no volume?
While it may not have many practical applications, triple integrating a region with no volume can be used in physics and engineering to solve problems involving infinite or theoretical scenarios. It can also be used in computer graphics to create three-dimensional models with no volume, such as a surface or a shell.
  • Calculus
9K
  • Calculus
