Trouble Solving a Diff Equation
Hi, i've been two weeks trying to solve this Diff Equation, but no success 'til now. I found your forum now, and I hope we can find a solution. I'm sorry if I'm posting this on the wrong section.
This problem looks simple, but due my formation (Engineering) and the fact that I've not used EDO for a while, makes this problem hard for me :)
It's a piece of a Control Engineering problem for a paper that I'm writing.
The equation is:
dy = (k + x)*(a/x+b/y)dx
The inital condition for y is a constant 'y0' and for x = 0. I need a analytic so I can prove some some properties of my controller.
I'll really appreciate your help
Answers and Replies
hunt_mat
1,741
25
I tried a few substitutions and I also tried maple and all came up a blank, what properties were you hoping to prove? They may well be proven without actually solving the equation.
ok, the full problem is:
the controller diff equation
dI/V = a*dg/g + b*dp/p
System dinamics:
System 1:
dV = dg
but the inital conditions for V is different from 0, a cst k
so V = (k + g)
System 2:
dg = I*dp/p
dp/p = dg/I
back to the controller DE,
dI/(k+g) = a*dg/g + b*dg/I
>> dI = (k+g)*(a/g + b/I)*dg
or
dI = (k+g)*(a*I+ b*g)/(g*I)*dg
>> g*I dI = (k+g)*(a*I + b*g) dg
I want to find I(t), so i can find g(t). Based in the input p(t).
53
Lemme' give it a shot in terms of I, g, and known p(t). You have:
[tex]\frac{I'}{k+g}=\frac{a g'}{g}+\frac{b g'}{I}[/tex]
So that's a DE for the function I(g). Right? Not 100% sure but think so. Suppose for now, I'm ok with that. Then note g can't be zero since that's a singular point of the DE. So let's solve this in Mathematica numerically for the function I(g) (can't use big I in Mathematica as a variable name) with just all the constants set to one:
Code:
myk = 1;
a = 1;
b = 1;
g0 = 1;
i0 = 1;
myp[t_] := 2 + t^2;
mysol = NDSolve[{g i[g] i'[g] == (myk + g) (a i[g] + b g),
   i[g0] == i0}, i, {g, g0, 15}]
myi[g_] := Evaluate[i[g] /. mysol] // First
So now I have I(g) and I solve the other equation in g:
[tex]dg=\frac{Ip'}{p}[/tex]
and for now, just let p(t)=2+t^2 and keep in mind I is a function of g. So I solve for g in Mathematica now letting g(0)=1:
Code:
mygsol = NDSolve[{Derivative[1][g][t]/myi[g[t]] == (2*t)/(2 + t^2), g[0] == 1},
 g, {t, 0, 2}]
myg[t_] := First[Evaluate[g[t] /. mygsol]]
Note how I specified i(g(t)) in that expression since previously I solved for i(g). So now I have g(t).
Now, let's back-substitute all that into the original DE an keep in mind that I solved for I(g) so to back-substitute into the DE in terms of t, I calculated:
[tex]\frac{dI}{dt}=\frac{dI}{dg}\frac{dg}{dt}[/tex]
Code:
In[149]:=
leftside = ((D[myi[g], g] /. g -> myg[1])*(D[myg[t], t] /. t -> 1))/(1 + myg[1])
rightside = (a*D[myg[x], x] /. x -> 1)/myg[1] + (b*D[myg[x], x] /. x -> 1)/myi[myg[1]]
Out[149]=
1.8982003067079452
Out[150]=
1.8981978130717898
That's a start since the left side is close to the right side. That may however not be what you want and I'm not sure everything is ok. May need to clean it up if it's close to what you want.
53
I didn't initially think to just solve the system simultaneously:
In[118]:=
a = 1;
b = 1;
k = 1;
i0 = 1;
g0 = 1;
p[t_] := 2 + t^2;
ttest = 2.3;
mysol = NDSolve[{Derivative[1][t] == (k + g[t])*((a*Derivative[1][g][t])/g[t] + (b*Derivative[1][g][t])/i[t]),
Derivative[1][g][t] == (i[t]/p[t])*Derivative[1][p][t],
i[0] == i0, g[0] == g0}, {i, g}, {t, 0, 5}]
myi[t_] := Evaluate[i[t] /. Flatten[mysol]];
myg[t_] := Evaluate[g[t] /. Flatten[mysol]];
leftside = D[myi[t], t] /. t -> ttest
rightside = (k + myg[ttest])*((a*D[myg[t], t] /. t -> ttest)/myg[ttest] + (b*D[myg[t], t] /. t -> ttest)/myi[ttest])
Out[125]=
{{i -> InterpolatingFunction[], g -> InterpolatingFunction[]}}
Out[128]=
19.888332975980877
Out[129]=
19.88832995172911
. . . glad I'm not being tested on this stuff.
Related Threads on Trouble Solving a Diff Equation
  • Last Post
  • Last Post
  • Last Post
